Road Grime
Road Grime
Question.
I just wash wash my car today. Somehow I've noticed tar like substance after the front wheels around the door panels or bumpers. I tried putting pressure with the sponge. Somehow it doesn't come off.
I've thought waxing would remove it, but it doesn't. Need help.
Any suggestions?
CLUELESS IN NYC
Any suggestions?
CLUELESS IN NYC
I also have this same problem, I thought I would post also, but then I saw your post.
I think mine is tree sap, but not sure. I have tried everything, I heard that the longer it stays on your car the more of your paint it eats up. I thought maybe there is a spray or something that can get rid of it? It's like a glue substance, it sticks to anything.
I've found something. I've spoken to a few close buddies. They say get the liquid version of "BUG&TAR REMOVER" Maybe do it before washing the car or after loosening the dirt.
Likely, if it is road grime, it is petroleum based, and I would use a petroleoum based cleaner, like Goof Off or WD40
1 - hose off the areas really well
2 - apply a liberal amount of G/O to the rag
3 - rub onto surface for a few seconds with light pressure
4 - apply more G/O to a clean area of the rag
5 - repeat 2-4 until gone
6 - rewash area very very very well with soap and water
7 - REpolish and REwax area thoroughly
HTH
EDIT:
Yeah this stuff is about the same. I've used it before; good stuff; very similar in make up as the G/O I think. Same afterwork applies
HTH
EDIT:
