Spend a little extra and get Kamikaze Miyabi or ISM coating from esotericcarcare which has it with $5 next day shipping. I just did 2 vehicles with the ISM coating this weekend and the results speak for themselves. I have also coated my ES's with 22Ple as well and that is also a great user friendly coating. I'll be using this Kamikaze though for the near future.
I don't think all of your options are tested here, but this guy is running an ongoing test on a bunch of different ceramic coatings and sealants. Avoid the 9H Mr. Fix, he tested it in the second video series and it barely lasted 2 weeks.
I ordered 2x CarPros CQuartz UK 3.0 50ml kits. I have 3 cars, I am hoping I can do all 3, but my primary concern is my truck and my wife's car as they live outside.
2 bottles are plenty. I have coated my 15GS350 twice, and still had 1/3 left in a bottle. You won't have a problem getting all 3 vehicles coated. I know this because I've coated a 2018 Dodge Ram Limited with 1 bottle, and had a little left. Now, prep work on the Ram was
Wife's Civic turned out great! CQuartz is a great product! Level of difficulty is a 4/10 for a moderately experienced detailer. If you can correct paint with a DA, you can do this. Will report back in a year with longevity test. One important note: If you don't have the ability to store the car indoors for 24 hours to let the coating cure, don't attempt. The coating just after install is a bit "wet", and will attract dust if left outside. That dust can dry into the coating.
I would honestly focus more on the level of prep work (correction) as that will matter more on overall shine, with that being said Ive been using CarPro products and have never had issue with. their products as they perform great granted they were installed and maintained correctly.
Not sure if you went with the uk 2.0 or 3.0 but the 3.0 is way easier to use.
Reason: removed quoted images...
PHEW....you guys really should delete his huge photos when using his Quote in a response! Scrolling thru them all over and over is tedious. LOL
IMHO- if you can afford to have a Ceramic Coat applied professionally, then that is the best way to do it. If not, you should do ALOT of research on its Application. The car must be SERIOUSLY cleaned and Clay Barred prior (Im sure you already knew this- sorry) From what you posted, I'd have to say that the CQuartz UK would be your best choice and its highly rated among detailers. The CQuartz Finest Reserve I went with can only be obtained and applied by Licensed Detailers (Im sure There's most likely a way around this) Despite knowing my way around Detailing, I'd be very hesitant to apply a Ceramic Coating myself. Matter of fact, they even used huge heat lamps to bake mine on. Not sure if you saw my Thread on this but if not, here is the link about it all. Im NOT saying this is the ONLY way to do things -simply stating what I know and went with. My PPF And Ceramic Coating
This one may give you some ideas on WHERE to obtain the best Products and Sources to purchase this gear. If they had Frequent Flyer Miles at AutoGeek - Id be writing this from a tropical island somewhere my friend! lol Sources and Products
Whatever you do, please post it all up here for others to see and learn. I'm open to new ideas all the time. Isnt that what this Forum is really for?
Prep work is key. After doing my truck, I found swirls on my hood that I had missed unintentionally. Now I need to figure out how to remove the coating (from the hood only) so I can re-do the paint correction and re-apply the coating.
From personal experience: I forgot my pillar and did not level off and removed excess Cquartz. 12 hours days, it would not come off without some polish and a lot of elbow grease. The area I'm talking about is right above the doors between that and the roof. I polished it off with a DA and reapplied. Once it's cured, I have not been successful removing it without a lot of work. Which IMO is a good thing.
Are the swirls really that bad to where you have to remove the coating and get them out? I got swirls in my car after washing it and drying it after polishing when shining a light on it but it had taken so long and I was so over polishing it another time I just applied the ceramic coat(GTechnique) anyway. Its going to get scratched anyways which has already happened from using a car cover, I figured I will just give it a light polish every year and the next time I apply the ceramic coat I will try to be more thorough. My car is black so everything shows up, just can't avoid swirls with soft black clear.
Yeah, its pretty bad. I am going to put some synthetic polymer sealant on it first and see if that will at least hide it. I am not hopeful though, as the swirls are not in the coating, but in the clearcoat itself. I just didn't have good enough lighting when I polished, because my truck only fits in the garage rear end first and the rear bumper literally against the wall. So I was trying to polish the front of the truck with the door closed, but all my lights hung from the ceiling at the back of the garage. Rookie mistake, and I have since installed more shop lights.
