Ceramic Coating
I am located in Southern California and want to get my 2020 NX ceramic coated and wanted to know which brands that you used and provide with pros and cons. Thanks.
I used Carpro UK CQuartz 3.0. I suggest that you purchase the kit containing 50ml and Reload spray and a 16 oz bottle of Eraser. The paint should be as perfect as possible. Dark colors will show swirls more than white. Clay bar, possibly buffer with polish(being you have a new car, you may be able to skip this step), wash, dry it and then spray wipe with Eraser just before applying the ceramic. You'll get two coats from the 50ml bottle. Do it in the shade on a cold car. Good directions included and easy to apply and wipe off excess. I used this brand based on another member's recommendation who had it over a year and was still satisfied. So far very easy to keep my car clean, haven't used the Reload yet but likely at 4-6 month mark for refresh.
Seabone726 (04-04-20)
CQ vs. CSL
Pros
- Both: Affordable
- Both: Readily available online
- Both: Easy to apply (forgiving on beginners)
- CQ: I have personal experience that it easily lasted 2 years on my GS350 with proper maintenance.
- CSL: The removal in the best part. It leaves a very slick feel on the paint at removal time. This lets you kind of know where you've coated and where you've missed. The ease of removal for CSL for me wins hands down.
- CSL: if using a topper, Gtechniq wins this one for me. EXO is fantastic.
- Both: Timing - You'll have to be sure to get your coating and removal timing down. Leave a spot too long and you'll ending up polishing it off.
- CQ: I personally don't like the the removal portion of CQ nearly as much as CSL.
- CSL: I don't like using the pipette to get it on my applicator. IMO extra step for no reason.
- CQ: If using a topper. CQ loses this one. Gliss was not impressive in my opinion.
I used 22ple HPC. I had no problems applying it and it was pretty easy to tell when to remove when it you could see the product flash. I ended up doing two coats on both of my vehicles and really didn't run into many snags. It was easy to use.
I waited overnight. I was working on it after work and after putting the little one down for the night so I was working night to night. So I applied one evening, let it flash and removed the excess. Then waited until the next evening for the second coat.
The coating will lock in any dust and imperfections on the surface. The more effort you put in to have a perfect surface, the better the finished surface will look. Save the applicator cloth you used for the first coat. The next day, when you see how rigid it has become, it should give you a better understanding of ceramic coating characteristics. You'll also be tossing the buffing cloth as that is ruined as well. A dark colored paint will show any mild scuffs and swirls in the surface.
Beachtyme (05-03-20)
Used CQuartz 2 yrs. ago and It worked great. Ready to reapply. How much prep work do I need to do? Do I need to remove the current coating by polishing, eraser and claybar and iron-X? Just want to know how to begin this process scince it has been on the car for 2 years.
It still looks great. Feels great. No iron in water. No swirls, etc. Inside garage about 95% of the time. I just assumed that after two years, it was time to reapply.
Greg@DI
Club Lexus Vendor Marketplace
04-26-09 11:50 AM
