Crazy glue residue on paint
Okay.... I am retarded.
In my effort to "glue back" the decals from underneath the hood, I accidentally got some crazy glue on the paint and it left a nasty mark that gets on my nerve every time I look at it.
Does anyone know how I can get rid of it?
Please help. I know some of you are going to say it doesn't matter but I am just pretty **** when it comes to little things like this.
Any ideas?
Thanks in advance.
Jon
Any ideas?
Thanks in advance.
Jon
Have you tried a heat gun? It could work considering it should heat up and soften the hardened glue so that you can safely scrape them out. It will probably leave a mark or some sort on the paint, but that can be remedied with some 3M paint care products. Right now you gotta get the glue out before it stays there forever!
Thanks for the tips. I appreciate it.
One problem though. I think the effectiveness of a heat gun would be limited because when I got the glue on the paint, the engine/hood was still very warm (hence, same as using a heat gun to heat up the area) and I still couldn't wipe off the glue residue even with Meguiar's Scratch X.
Is there any other way that I can get it off? It's not so bad looking at this point. There's just one streak of glue mark left.... But still... I wish it wasn't there on the paint.
Jon
Jon
Not sure if you want to try this, but get some very fine grit wet/dry sandpaper (like 1500 or 2000 grit) from Walmart or any auto parts store. Cut up a few small pieces from it so that you can handle OK with your fingers, then try sanding down the glue mark. Do not sand it completely away, or else you'll start scratching the paint. Clean up the area, and apply some rubbing compound to make it shiny and scratch-free. Rubbing compound is like liquid sandpaper, and therefore should only be used if necessary since it takes away the original finish of the paint. Hope this helps.
This is only a suggestion. I have not done this therefore take it a only a suggestion.
Heat is not going to take out crazy glue. Normally I would use acetone or nail polish remover to remove crazy glue from my skin or items I am gluing. Don't know how it would react with the Lexus paint. You could test it on a area that can't be easily seen. The nail polish remover is a bit milder than the full strength acetone. I would applied the nail polish remover on a Q-tip and gently rub on the glue area then wipe and rinse with water afterward. How big is the crazy glue spot on the paint?
Chu...
Chu...
Thanks again!
One question please. If rubbing compound is the same as liquid sandpaper, would it be okay if I simply use it directly on the glue residue?
Wouldn't it have the same result as me using the actual 1500 or 2000 grit sandpapers on the affected area?
Jon
Jon
Try acetone (nail polish remover). That's primarily what they put in those "crazy glue remover" products they sell.
Test it on an inconspicuous area of the paint, say, under the front bumper etc. just to be sure. But generally acetone won't hurt cured urethane enamel. Cheers.
Good idea.
I was actually going to try vinegar on the affected area but I haven't had the chance to do so yet.
The spot is not too big. It's actually caused by excessive glue flowing out of the area where I applied it. Therefore, it looks like a streak of thin line on the surface.
I'll give this a try and see how it works. If it doesn't work, then I guess I'll really have to sand it as lexusk8 suggested.
Thanks.
Jon
Thanks.
Jon
Chu...
Chu...
Thanks for your help guitarman!
I'll get some of this good stuff as soon as I get off work tomorrow. Would it matter if I let the crazy glue sit over night?
Jon
Jon
Not sure if it will matter at this point. One night shouldn't make too much diff.
Use a cotton terry towel and don't rub hard. Keep it wet with acetone and be patient.
Thanks a bunch! I appreciate your help guitarman.
Jon
Jon
Happy to help
If you have a dull spot afterwards, simply polish it out with something like KIT Scratch-Out or Meguiar's Scratch X , even a swirl remover. Not saying you will get dullness, but don't freak if you do.
Re: Happy to help
I gotcha. Thanks!
Time to pay my local cosmetic/beauty shop a visit tomorrow.
Jon
Jon
superpats
Automotive Care & Detailing
04-11-05 10:19 PM
