1992 SC400 - stardust (a tasteful OEM+ build)
The following 7 users liked this post by wellsolong:
Barbary (09-29-23),
joewitafro (10-11-24),
KahnBB6 (09-29-23),
KiroLS (09-30-23),
SC400slide (10-18-23),
and 2 others liked this post.
#33
Thanks @ThomasGS4, that helps because I wanna make sure the colors are correct for the car while unifying them a bit.
I'm still undecided if I want to get replace the orange-y gold backlighting in the cluster with white. On one hand, I like that it's original and it would continue matching the backlighting of the shift bezel. I also like how it looks at night. But during the day it doesn't do much for me. I'll probably just keep it, perhaps the blue needles are just throwing me off since there's no blue anywhere else. So I'm looking forward to at least red needles.
P.S. I finally reached 90k the other night!
Boy I get envious of gauges like yours. mine have never been right ever since I've had it. The needles have read right but the backlights have been sporadic at best
Nice garage too
wellsolong (01-24-24)
#34
Hi everyone, it's been awhile but basically the budget hasn't allowed for any updates until recently hahah.
So I decided on getting another cluster unit from Tanin instead of sending mine in, that way I can have the original around too. In the end, I opted for green needles and white clock / odometer. Not OEM colors I know, but there's so many green lights in the cabin already (key ring, pedal lights, climate control, etc.) that I figured green needles would match a lot better. I'm excited to install it once it comes in!
Some other things: after the subframe and differential bushings job, it's pretty dang tight back there handling-wise but now there's a pretty audible whine on acceleration and a bit of a clunk on deceleration that annoys me. It's not audible at high speeds. Not sure if this noise existed and is now audible without rubber bushings, or if something is now up after the driveshaft / differential was put back in.
Still have the fuel smell in cabin after the car sits for a bit. Gets worse if there's less fuel in the tank. The smell goes away pretty quickly after cracking the windows or running the AC in fresh air mode at least. Will look into this more soon.
Bimmerbill (01-25-24)
#35
Cluster update: in the very end, decided on red needles. Extremely happy with this one from Tanin. The lens is near perfect and it looks so fresh. I was a little worried it'd look too "new" and out of place but it looks amazing and is a definite upgrade. Also happy that replacing the cluster is pretty easy, although those connectors are pretty dang stubborn.
wellsolong (04-08-24)
#37
I wonder if it can be attributed to the bushings but handling has been great! Besides those bushings and solid steering rack bushings, I don't have anything else suspension-wise except coilovers. I recently test drove an SC with factory everything and it was so bouncy and handling felt really loose all around. So it made me feel like it's been worth it. Hopefully you can get it done some day!
RudysSC (04-15-24)
#38
A little update that I can't really post a photo for: I put in a black felt strip around the forward center console since the old material had corroded away causing the console to move around and squeak on every little bump. Totally silent now and you can't even see the felt unless you put your head below the rearview!
I love how easy it is to fix little quality issues in this car.
RudysSC (04-15-24)
maclem8223
Lexus Vehicles Classifieds
32
10-17-11 06:42 PM
