CleanSC: The Reveal
#92
Originally Posted by mikeloc24
What happened with the header project Jose?
The design is much the same except these bolt to a turbo.
#93
man I got to hand it to you you,ve got the cleanest, freshest SC I've seen you did a great job Please dont get mad if I sweat you for some tips
,you da man
'''G''
vitaminSC
95 sc 400 up & coming
,you da man
'''G''
vitaminSC
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#96
Originally Posted by vredniykot
i believe he has gun-metal-mania ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
#97
Bump because this is one of the sickest looking SC's out there...giving the noobs and ricers a much needed CLUE.
Jose, the car looks frickin' amazing. Congrats on the excellent job, a true labor of love.
#98
Thanks, Mike.
#100
First of all, Clean SC, beautiful car... I got a white one too so you know I'm feelin' yours. Anyway, I was wondering how much clearance you have in the front between your LS400 brake upgrade and your wheels (are they high disc). If I remember correctly you are running 19x8.5 (+43 offest) and 19x9.5 (+38) with tires being 245/35/19 and 275/30/19. I am getting 19x8 and 19x10's and I am still trying to figuring out my offsets and whether or not the wheels will clear the LS upgrade. They are Iforged RS Aeros and the offset can be custom. I want the most lip possible with enough clearance for the LS brake kit. Think you can help me out? One more question, how much more clearance is needed with the LS brake upgrade in comparison to the stock rotor/caliper set up?
#101
Yes, my wheels are high disk and I have 5mm clearance from the spoke to the caliper. You need about 70mm from the rotor face to the spoke to clear the LS/Supra brakes.
As for your iForged application, just tell them you need to clear Supra brakes (or just get the wheels made for the Supra) and you should be good to go. Tell them exactly what you want and they should set you up just fine. I can't speak for iForged so I can't guarantee it but if you order a high-disk Supra setup and request the most lip possible, you should be just fine.
