Build Threads Details on Club Lexus LS400 owner vehicles
Project: COLOSUS
Old 06-13-11, 08:46 AM
  #76
JamesN
JamesN's Avatar
Looking great. Great job on relocate the battery for the meth tank.
Old 07-18-11, 10:54 AM
  #77
Boyscout
Boyscout's Avatar
Methanol tank is now covered and hidden
Before:
http://i875.photobucket.com/albums/a...-46-46_541.jpg
After:
http://i875.photobucket.com/albums/a...-39-50_944.jpg
Old 08-31-11, 11:19 AM
  #78
Boyscout
Boyscout's Avatar
Headers go in this weekend and custom exhaust gets made/installed next week
Old 08-31-11, 07:41 PM
  #79
Raddison
Raddison's Avatar
How have I never seen this thread?? Talk about doing work!
Good stuff man, keep it up!
Old 09-06-11, 08:48 AM
  #80
Boyscout
Boyscout's Avatar
Header Install:
I would rate this as a 7/10 difficulty due to the fact that the front subframe had to be lowered to be able to remove & install the headers.
Right Side:
you can see the S&S header has a much better flow design
http://i875.photobucket.com/albums/a...-42-10_764.jpg
http://i875.photobucket.com/albums/a...-25-05_132.jpg
http://i875.photobucket.com/albums/a...-25-28_952.jpg
http://i875.photobucket.com/albums/a...-26-08_508.jpg
Left Side: this side was more difficult because of the steering box and the clearance issues
http://i875.photobucket.com/albums/a...3-33_921-1.jpg
http://i875.photobucket.com/albums/a...4-01_202-1.jpg
you can see the position of the O2 sensor location is a bit "off". This causes the O2 sensor to hit the steering box (pic below). I dont know if this is a fab error just on my headers or if all the S&S headers have this issue. It could also be that the headers are for a LS400 rather than a Celsior, in which the steering box is on the other side.
http://i875.photobucket.com/albums/a...-14-16_944.jpg
http://i875.photobucket.com/albums/a...1-29-26_69.jpg
http://i875.photobucket.com/albums/a...-29-50_288.jpg
http://i875.photobucket.com/albums/a...-30-05_546.jpg
http://i875.photobucket.com/albums/a...-30-46_155.jpg
very little clearance between the header and the steering box (~1/4"), as well the O2 sensor 'stem' contacts the steering box. I had to gently bend the 'stem' a bit as I jacked the subframe back into position. I also wrapped the portion of the header around the O2 sensor with heat wrap.
http://i875.photobucket.com/albums/a...-13-15_757.jpg
I made some flanges and cut some straight pipe as a temporary spacer (no cat) until i get the rest of the exhaust fabricated this week.
http://i875.photobucket.com/albums/a...-43-29_382.jpg
http://i875.photobucket.com/albums/a...-43-37_171.jpg
http://i875.photobucket.com/albums/a...-43-51_194.jpg
Old 09-06-11, 11:24 AM
  #81
deanshark
deanshark's Avatar
Those headers look awesome, much better flow on them then stock. I think I saw a shorter O2 sensor that fits the LS, not sure about the Celsior. I can't remember where I saw it though. Do you plan on wrapping the headers for the heat, especially the one that had the heat sheild? (right side)
Old 09-06-11, 11:26 AM
  #82
LiCelsior
Retired
LiCelsior's Avatar
those look good, i hope that batch wasnt the one that was prone to cracking. how difficult was it installing those?
Old 09-06-11, 12:03 PM
  #83
Boyscout
Boyscout's Avatar
both the stock headers had heat shields. I just removed one of them to show the difference in design.
I believe the S&S headers are ceramic coated stainless steel, so I am not going to wrap them. Plus, the clearance is good in all spots except by the steering box, so air flow should be fine for cooling.
O2 sensors for the LS400 and Celsior are identical. if you can find out where you saw them, please let me know...i want to replace both anyway.
Old 09-06-11, 12:06 PM
  #84
Boyscout
Boyscout's Avatar
Installation wasnt that bad, but the hard part was lowering the subframe and accessing all the studs. some of the nuts had to be tightened with a wrench rather than a socket due to the location.
Old 09-08-11, 05:56 AM
  #85
Boyscout
Boyscout's Avatar
Exhaust is done.
2.5" from the headers to the Y-pipe
3" down the center to the rear Y-pipe
2.5" from the rear Y-pipe to the muffler flanges.
Going to take some pictures this weekend
Old 09-08-11, 11:37 AM
  #86
Rollaboy
Rollaboy's Avatar
Its a nice project coming along there. Where did you get those S&S headers? I have looked around but no one is making headers for our LS400 :-( I really could use a pair for my full stainless steel exhaust project in the near future. But read alot about them S&S headers cracking. Sure dont want that to happen :-(
What about the methanol injection. Is it working good? I know you got supercharger also now but i wonder how much that would do for like a starter tuning until i get the money for a supercharger. It should be fairly easy to install right?
Keep up the good work Boyscout
Old 09-09-11, 10:08 AM
  #87
Boyscout
Boyscout's Avatar
i believe they dont make the headers anymore. The cracking issue was only with certain batches, but ill be keeping an eye on mine for sure. if they do crack i will just TIG it up.
the methanol injection is to lower the increased intake air temperature due to the supercharger. Not sure how much it would help a naturally aspirated engine.
Old 09-09-11, 10:30 AM
  #88
PureDrifter
BahHumBug
PureDrifter's Avatar
rollaboy, buy PPE headers
Old 09-09-11, 02:35 PM
  #89
Rollaboy
Rollaboy's Avatar
Woow PPE where, what.. Never heard of it?? Just google'd it and found this: http://www.ppeengineering-onlinestor...?categoryId=32
But do they fit 91' LS400? It says LS430 and SC400. Looks preeeetty damn nice :-P Anyone had luck with those? No cracking etc.
If they do, ooohhhh im gonna write them on my wishlist for christmas!!
Old 09-09-11, 02:48 PM
  #90
PureDrifter
BahHumBug
pm them
https://www.clublexus.com/forums/clu...group-buy.html
they should be able to get you a set that will be within range with reasonable modifications to your current exhaust setup (changing orientation or cats i THINK?)
Quick Reply: Project: COLOSUS
