Build Threads Details on Club Lexus SC owner vehicles
IT's Here 2jzgte vvti & Garrett GT3582R
Old 02-02-09, 05:31 AM
  #226
1siksc
1siksc's Avatar
what parts did you have to buy to do the swap? Rotors and calipers?
Old 02-05-09, 02:51 PM
  #227
TURBO819
TURBO819's Avatar
1: 95-00 Ls400 Calipers
2: 95-00 Ls400 Rotors (oem)
3: 95-00 Ls400 Brake Pads (oem)
3: Ls400 Caliper Mounting Bolts
4: SCx00 Gaskets for the Brake Lines
Like StiCk3 Posted
Originally Posted by StiCk3
No you are not the only one. I did post it on an LS400 brake review thread a while back, but there still is no clear answer on why just a few of us realize this. Just a little grinding near the upper mounting hole will do the trick (air/power tools FTW). I don't know if it's an issue with certain year SCs or with all of them.
I just notched the back of the Calipers for clearance. I spoke to a few others that did the Ls400 Swap and they did not need to do any modifications other than trim back the Shield. So it might in fact be Year specific
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-1911207.jpg
Old 02-26-09, 03:06 PM
  #228
TURBO819
TURBO819's Avatar
Default One More Thing Off The List
One More Thing Off The List:
I finally got the Rear Tires
245/45/17
285/40/17
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-1911205.jpg
Old 02-26-09, 04:43 PM
  #229
flipboi
flipboi's Avatar
so was ur sc manual alrdy b4 the swap? and is there a diy how to install manual tranny and clutch assembly to the auto?
Old 02-26-09, 06:07 PM
  #230
TURBO819
TURBO819's Avatar
Default Auto To Manual Swap Links
That's a NO & Yes. When I got the car it was an AUTO. I did the Manual Swap before I did the 2jzgte Swap.
This is a link that you might want to check out. ( Post # 2 )https://www.clublexus.com/forums/per...-my-sc400.html
This is a link that you might want to check out too. ( Post 161-163 )
https://www.clublexus.com/forums/per...-thread-5.html
I know it's for a 6 Speed Supra Swap but a lot of this information can be adapted for the 5 Speed SCxxx Swap. I hope this Helps
http://www.mkiv.com/techarticles/aut...wap/index.html
Old 02-26-09, 07:02 PM
  #231
flipboi
flipboi's Avatar
This is a link that you might want to check out. ( Post 161-163 )
wow tyvm btw i really like what u did to ur car someday i wanna do the same just low on funds right now lol and its so hard to look for the parts.. i dont know where to look
Old 02-26-09, 10:36 PM
  #232
StiCk3
StiCk3's Avatar
now that the swap is done...
big power + fat tires = some time slips
Old 03-01-09, 02:59 PM
  #233
TURBO819
TURBO819's Avatar
This is one of the SCxxx PART's GUY. Great Prices on Quality Lexus Parts (SCxxx's). He supplied many with W58 Swap Parts. He supplied me with parts to do TWO W58 Swaps. Just PM him from time to time to see what he has.
https://www.clublexus.com/forums/members/667-aliga.html
Old 03-13-09, 06:23 PM
  #234
TURBO819
TURBO819's Avatar
Default wood grain center console
98 - 00 Auto Wood Grain Center Console or 92 - 97 Manual Center Console. Which One looks better?
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-99-00-woodgrain-center-console.jpg
Old 03-13-09, 08:39 PM
  #235
StiCk3
StiCk3's Avatar
im kinda diggin the wood trim. I say keep it.
get some time slips!!
Old 04-26-09, 06:14 PM
  #236
TURBO819
TURBO819's Avatar
Default 350Z Touring 18" v.1
350Z Touring 18" v.1 Front Size: 18x8.0 Offset: +30mm Weight: 26.56lbs Rear Size: 18x8.0 Offset: +30mm Weight: 26.56lbs How do they Look ??????????????????
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-99-sc300-with-touring-350z-rims.jpg
Old 04-27-09, 08:26 AM
  #237
ICONYQ
ICONYQ's Avatar
hmmm look nice. What are the specs???
Old 04-27-09, 11:01 AM
  #238
OneJay
OneJay's Avatar
IMO the supra wheels looked better, but if you want 350z wheels, get the 5 spoke ones.
Old 04-27-09, 03:21 PM
  #239
TURBO819
TURBO819's Avatar
Touring 18" v.1 18-inch Touring wheels V1 models from 2003 through 2005 model years. Aluminum Alloy Front Size: 18x8.0 Offset: +30mm Weight: 26.56lbs Tire: 225/40-18 Rear Size: 18x8.0 Offset: +30mm Weight: 26.56lbs Tire: 245/40-18
Old 04-27-09, 03:29 PM
  #240
TURBO819
TURBO819's Avatar
They are for my IS300. I just installed them to see if they would clear the LS400 Calipers & Check the offset on the SCxxx. I would like to install some LS400 Calipers on my IS300
Quick Reply: IT's Here 2jzgte vvti & Garrett GT3582R
