nay on the six spoke, don't think i'd like em on an IS either.
Just to be clear though, they fit LS400 brakes right?
They Clear the LS400 Calipers. I think once they are Powder Coated Black they would look Good on the IS300. I really like sticking with OEM Rims so it would be easy to replace down to road if something should happend.
Front Supra TT Rims With LS400 Front Calipers Installed. I just need to get 2 @ 285/40/17 to install the rear Supra TT Rims
On a side note: I had a little trouble Installing the Calipers. After trying to install the calipers a few times (A Few Hours in 26 Degree Weather) I notice that I needed to notch the back of the calipers because the caliper was hitting the UPPER mouting bracket (unable to bolt the Caliper mounting bolts) No one every POSTED that this needed to be done. Am I the only one that had this mounting PROBLEM? But it's all good now.
Where did you get the Lexus centercaps to fit the TT rims? Do they come from another Lexus wheel? If so, which wheel?
Project Two Tone (Center Console)
Parts Supplied by (Club Lexus Member aliga)
Passengers Side Air Bag will be Painted to match the Dashboard & IS300 Steering Wheel & Air Bag will also be Installed.
