IT's Here 2jzgte vvti & Garrett GT3582R
#350
Look good Kenny thinking about doing the same next week keep blowing the pipe off.
You are getting there slowly man can't wait to see the finish product. keep them coming
#353
I decided to go with ATP'S ATP-FTG-052 Banjo Fitting, 14mm hole (for 14mm bolt) with -6 AN male flare. So I can use 90 Degree -6AN Lines to turbo Water Lines
These will replace the two items circled in red
#355
A Few Problems
The other problem was with the Hot Side Intercooler Pipe. I think I placed the wrong angle on the pipe before I took it to be welded. I cut and placed a new angle. Hopefully I can link up with AL the Welder on Monday
#359
I am so Lucky
Well I was trying to figure out how to solve the issue with the Hard Coolant Line being about 1/2" to 1" away from the downpipe. So I decided to Surf the Web. I notice in a picture that the 1jzgte Hard Coolant Line exit was 90 degrees vertical vs the 2jzgte being 45 degrees to 90 degrees horizontal. This here might be my problem solver. The problem now is how to get my hands on one??? Post a WTB ad??? Of course. To my surprise 2 hours & 3 minutes late. JDMPO (Club Lexus) Member Posted up. He has one. He even went the extra mile of going to his shop. Getting the item. Taken a picture. Too make sure it is the item I needed. It is. All I can say is THANKS YOU VERY VERY MUCH. I thought that this would be like finding a Needle in the Hay. The Power of Club Lexus. The Power of the Internet. Just think a few year prior if you did not know someone that knew someone that knew someone that knew someone. You were out of LUCK
