IT's Here 2jzgte vvti & Garrett GT3582R
#378
Just a case of that two steps forward and one step back. Wired up the injector harness. Installed the lower intake manifold and was in the process of plugging in the injectors and guess what??? The injector plugs are different. Hopefully I can get the MKIV injector Clips before weekend.
I wish I knew that they were different. I would have ordered them a long time ago.
#379
Yes i forgot to tell you that!! I saw it on SF the VVti GTE clip and Non VVti GTE clips are different..I didn't even think about it man.
It's coming along looking better everyday...
#382
Looking good as always, I will start on mine today!
What did u use to cap off the oil feed for the stock twins? I want to cap the rear one cap the rear one off and use the front one...
#389
You dont need different injector clips, you need to cut the side locator tabs off the clips, the top tab sticking out will ock the injector clip on the injector, i have OEM 550s in my aristo motor and it worked just fine, been makin great power no issue at all.
hope you get this before youorder more clips
#390
Parts & Price List
01: Aristo 2jzgte vvti Engine With Uncut Harness $1885.00
02: Aristo 2jzgte vvti ECU $333.00
03: Phoenix Tuning Hybrid Engine Harness SC300 / Aristo (Club Lexus Member Dr.Tweak) $750.00
04: Supra Twin Turbo Throttle Cable (SupraForum Member) $26.00
05: Supra Twin Turbo Side Mounted Intercooler Hose & Pipes (SupraForum Member) $65.00
06: Snap Performance 3" Down Pipe (Club Lexus Member Supra600) $280.00
07: 98-00 SC300 Upper/Lower Oil Pan & Engine Wire Harness (Club Lexus MemberR J Dist) $275.00
08: SC300 Timing Belt (13568-49036) $26.27
09: Fuel Return Line (Summit) SUM-PUMPKIT1 $85.95
10: Supra Twin Turbo Thermostat (90916-03093) $19.70
11: Supra Twin Turbo Thermostat Gasket (16325-62010) $5.72
12: Supra Twin Turbo Water Pump (16100-49846) $177.78
13: Supra Twin Turbo Gasket (90430-12005) x 2 $1.10
14: Supra Twin Turbo Union (90405-09174) $7.14
15: Supra Twin Turbo Pipe Turbo Oil (15474-88401) $44.11
16: Supra Twin Turbo Gasket Turbo Oil (15471-46010) $2.83
17: Supra Twin Turbo Hose Turbo Oil (15491-46020) $15.38
18: Supra Twin Turbo Hose Turbo Oil (15492-46020) $15.38
19: Supra Twin Turbo Pipe Turbo Oil (15482-46011) $96.45
20: Supra Twin Turbo Gasket Turbo Oil (15472-46010) $4.62
21: Supra Twin Turbo Bolt, Stud (90116-08348) x 2 $1.07
22: Supra Twin Turbo Nut (90179-08153) x 2 .98
23: Supra Twin Turbo Upper Radiator Hose & Strut/Springs (Club Lexus Member RikTT) $100.00
24: AEM Wideband UEGO Gauge Kit (30-4100) $205.00
25: DEFI 52mm WHITE RACER BOOST GAUGE (DF06503) $173.95
26: Supra Twin Turbo Side Mounted Intercooler (Had This item Since 1999. I Think I Paid) $125.00
27: T-Bolt Clamp (S&K Speed) x 2 $6.99
28: T-Bolt Clamp (S&K Speed) $8.99
29: Antifreeze Toyota Supra Twin Turbo (00272-1LLAC-01) $30.16
30: Supra Twin Turbo Fan Blade (16361-46060) $144.51
31: 98-00 GS 300 Aristo Ram Air Intake $34.00
32: Walbro 255 Fuel Pump (Club Lexus Member $hogunn) FREE
33: LS400 Front Calipers (Club Lexus Member aliga) $200.00
34: Supra Twin Turbo Rims (Club Lexus Member Erollinc) $535.00 Shipped
35: W58 Transmission (Club Lexus Member aliga) $1000.00
36: FlyWheel Bolts (90910-02103)
37: Hose,Ventilation (12263-46010)
38: Hose,Ventilation (12264-46010)
39: INSULATOR ASSY (12360-46111) Supra Twin Turbo MKIV Motor Mount X 2 $69.72
40: Sensor, Water (89422-16010) (2000 Toyota Corolla Three Wire Water Temperature Sensor) $53.79
41: Engine PCV Valve (12204-46020) Cost 4.10
42: Engine PCV Grommet 90480-18001 Cost 4.83
43: Intake cam cover gasket VVTI 1213-46030 Cost 11.20
44: Intake cam cover gasket VVTI 1214-46030 Cost 11.20
45: Rod Bolts (13265-46020 ) List 3.43 Cost 2.58 X 12
46: Rings Set (13011-46051) List 237.55 Cost 175.00 [ std only]
47: Snap Ring (90521-25004) List 2.34 Cost 1.79 X 12
48: Main Bearing (11071-46020-03) List 29.79 Cost 22.75
49: Main Bearing (11701-46020-03) List 27.93 Cost 21.32 X 2
50: Main Bearing (11701-46020-02) List 27.93 Cost 21.32 X 4
51: Thurst Washer Set (11011-46030) List 40.98 Cost 31.00
52: Main Cap Bolt (90910-02104) List 4.17 Cost 3.00 X 14
53: Mkiv Twin Turbo Full Engine Gasket Kit (04111-46094 ) List 480.77 Cost 365.00
54: Mkiv Twin Turbo Oil Pump Assembly (15100-46052) List 226.76 Cost 173.14
