Build Threads Details on Club Lexus SC owner vehicles
IT's Here 2jzgte vvti & Garrett GT3582R
Old 12-31-09, 09:28 PM
  #391
TURBO819
TURBO819's Avatar
Default Garrett GT3582R .82 Parts & Price
1 • Garrett GT3582R .82 ($1300.00)
2 • Greddy Style Exhaust Manifold
3 • Tial V44 With .8 Bar (11.60 psi) ($339.90)
4 •3" Down Pipe with V-Band ($110.00)
5 • SYNAPSE SYNCHRONIC BOV BLOW Off VALVE ($180.00)
6 •Custom 90 Degree, -10 AN Female to Male -10 AN
7 • Fitting, Hose End, 45 Degree, -10 AN Hose to Female -10 AN, Aluminum, Black Anodized, Part Number SUM-220086B ($16.95) X 1
8 • Fitting, Hose End, 90 Degree, -10 AN Hose to Female -10 AN, Aluminum, Black Anodized, Part Number SUM-220087B ($16.95 ) X1
9 • Fitting, Hose End, 90 Degree, -6 AN Hose to Female -6 AN, Aluminum, Black Anodized, Part Number SUM-220687B ($13.95 ) X 3
10 • Fitting, Hose End, 45 Degree, -6 AN Hose to Female -6 AN, Aluminum, Black Anodized, Part Number SUM-220686B ($13.95 ) X 1
11 • Russell Performance (632153) Pro-Classic, Braided Nylon, Black with Blue Tracer, -10 AN, 3ft Part Number RUS-632153 (28.95) X 1 (Oil Return Line)
12 • Russell ProClassic Hose (632063) Pro-Classic, Braided Nylon, Black with Blue Tracer, -6 AN, 6 ft.(Water Lines To & From Turbo)
13 • 24" Oil Feed Line -4 AN Female To -4 AN Female
14 • Custom 90 Degree, -10 AN Female to Male -10 AN
15 • Oil Return Gasket - GT Series Part Number Code: GRT-GSK-008 (Price: $3.00) x 1
16 • -4 size Oil inlet fitting for GT28/30/35R with built-in restrictor Code: ATP-OIL-021 (Price: $12.00) x 1
17 • Oil Return Flange with integrated -10 Flare for GT15 Through GT35R Code: ATP-FLA-019 ($29.00) x 1
18 • T4 Divided Turbine Gasket Code: ATP-GSK-014 ( $9.00) x 1
19• Fitting, Swivel, #4AN Flare, Male to Female, 90D Code: ATP-FTG-016 ($7.95 ) x 1
20 • Banjo Fitting Kit, (1) Banjo fitting 14mm hole (for 14mm bolt) with -6 AN male flare Code: ATP-FTG-053 (Price: $29.90)
21 • 90 Degree aluminum Pipe to be welded to the Compressor housing x 1
22 • Fitting, Adapter, AN Flare to Metric, -4 AN to 12mm x 1.25 Male, Aluminum, Blue Anodized,Part Number 9919BFFERL ($11.69) X 1
23 • Fitting, Adapter, Straight, Male -6 AN to Male 3/8 in. NPT, Aluminum, Blue Anodized, Part Number SUM-220648 ($2.95) x 1 Welded to the Water Neck
24 • 4" OBX Aluminum Pipe 45 degree Intake With Modified MAF Housing ($29.00)
25 • CXRacing 2.5" Aluminum Piping Pipe Kit ($79.98)
26 • 5 X 2.50" Polished Aluminum Pipe 90 Degree. L Pipes ($96.00)
27 • 3" 90 Degree for on the cold side off the intake (29.00)
28 • AEM Dryflow / dry flow air filter 4" x 9" (53.52)
29 • AEM F/IC Fuel Ignition Controller ($225.00)
30 •Oil Drain Flange for 1JZ/2JZ Oil Pan (driftmotion.com) ($20.00)
31 • Supra Twin Turbo 550's Injectors ($180.00)
32 • MKIV 550's Injector Clips Part Number 90980-11154 ($6.11) each
33 • Supra Twin Turbo Resistor Pack Part Number 28515-46010 Or 079960-0710 ($100.00)
34 • Precision Turbo 750hp Front Mount INTERCOOLER Length - 31.5 in Height - 10 5/8 in. Width - 3.5 in. Inlet & Outlet - 2 3/4 in. ($437.00)
35 • 1jzgte Hard Coolant Line ($40.00)
36 • SYNAPSE Synchronic BOV Anti-Stall Kit for MAF Vehicles ($49.95)
37 • NXS MOTORSPORTS MANUAL BOOST CONTROLLER ($19.99)
38 • OBX STAINLESS STEEL VBAND V-BAND V BAND CLAMP 3.0" 3"
49 • Silicone Straight Hose Coupler 4.0" Black
Old 01-01-10, 09:32 AM
  #392
speed6
speed6's Avatar
where did you get the injector reistor pack?
Old 01-02-10, 03:48 PM
  #393
TURBO819
TURBO819's Avatar
Default A Little Different
aliga came through with a few parts I have been looking for.
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-001.jpg   IT's Here 2jzgte vvti & Garrett GT3582R-picture-002.jpg   IT's Here 2jzgte vvti & Garrett GT3582R-picture-003.jpg   IT's Here 2jzgte vvti & Garrett GT3582R-picture-004.jpg   IT's Here 2jzgte vvti & Garrett GT3582R-picture-006.jpg
Old 01-02-10, 03:50 PM
  #394
TURBO819
TURBO819's Avatar
Default A Few More Parts
I just need a few more parts
Black Carpet
Black Center Console
And may be Lower Door Panels
I would like to get my Interior to look like the last Two Pictures
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-007.jpg   IT's Here 2jzgte vvti & Garrett GT3582R-picture-008.jpg   IT's Here 2jzgte vvti & Garrett GT3582R-picture-011.jpg   IT's Here 2jzgte vvti & Garrett GT3582R-lexus_sc430-2009_pebblebeach_i02-800.jpg   IT's Here 2jzgte vvti & Garrett GT3582R-lexus_sc430-2009_pebblebeach_i01-800.jpg
Old 01-05-10, 07:00 AM
  #395
99SC42
99SC42's Avatar
Wow that's nice.
Kenny i was wondering where you got the fittings from the one that goes on the Turbo right before the Oil drain line.
My manifold won't clear the return line from the bottom and it looks like i have to run the lines in between the manifold runners.
Sorry not trying to hijack your thread sir....thanks
Old 01-05-10, 10:53 AM
  #396
TURBO819
TURBO819's Avatar
Originally Posted by quickGS300
Wow that's nice.
Not at all. That's the point of this Thread. To help other as well as myself. Which one are you referring to??? Is the one in the picture below???
http://www.atpturbo.com/mm5/merchant...gory_Code=GTBB
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-20.jpg   IT's Here 2jzgte vvti & Garrett GT3582R-picture-19.jpg   IT's Here 2jzgte vvti & Garrett GT3582R-picture-277rr.jpg
Old 01-05-10, 11:03 AM
  #397
97-SC300
97-SC300's Avatar
sick build, this car it turning out to be so nice. keep it up man.
Old 01-05-10, 12:17 PM
  #398
99SC42
99SC42's Avatar
Yep that's the one i am talking about, I there any way you can clock the fitting so the return line doesn't go in between the runners?
Thanks Ken.
Old 01-09-10, 02:48 PM
  #399
TURBO819
TURBO819's Avatar
Default SCxxx Alive Again
http://www.youtube.com/watch?v=tp-xVplrUos
The past Three Days I was having a lot of problems trying to get My SCxxx to start. I Double and Triple checked everything with no luck. I spoked to ChevyEater and was told to plug in my Temperature Sensor. I did not have it plugged in due to the fact that I changed from a Two Wire Temperature Sensorto a Three wire Temperature Sensor and I still did not get shippment on the Temperature Sensor plug harness. I switch back to the Two Wire Temperature Sensor and the SCxxx started right up. I have a little coolant leak so I will address that later.
Old 01-10-10, 11:12 AM
  #400
StiCk3
StiCk3's Avatar
It lives!!! I think you have yourself a great looking car, finish line is almost in site...
Post some drive vids when you can!
Old 01-10-10, 01:37 PM
  #401
Wicked SC
Wicked SC's Avatar
Congrats!!! Sounds real good and healthy!!!
Old 01-12-10, 12:47 AM
  #402
Brownmagic
Brownmagic's Avatar
Kenny.. I gotta take pics of this car along with Gazi's soon
When the weather breaks up a bit
Old 01-20-10, 07:43 AM
  #403
99SC42
99SC42's Avatar
Hey Ken the fittings in the first picture on the Post #395 can you please tell me the Part# i am running into the same crap, I will never ever buy Ebay manifold.Thanks Ken
Old 01-20-10, 08:12 AM
  #404
TURBO819
TURBO819's Avatar
quickGS300. Which Fitting ??? The very first is. http://www.atpturbo.com/mm5/merchant...gory_Code=GTBB
OR are you referring to picture number one ??? Picture number Two is with http://www.atpturbo.com/mm5/merchant...gory_Code=GTBB and the two fitting on the left. If so the fitting in picture number one was made up at Morland Hose and Belting where in NYC. There is no part number for those fitting.
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-25.jpg   IT's Here 2jzgte vvti & Garrett GT3582R-picture-26.jpg
Old 01-20-10, 08:49 AM
  #405
99SC42
99SC42's Avatar
Yes those in the picture above thanks...
Quick Reply: IT's Here 2jzgte vvti & Garrett GT3582R
