IT's Here 2jzgte vvti & Garrett GT3582R
#454
My oil pressure light came on shortly followed by a Rod Knock. I am thinking the Oil Pump failed leading to oil starvation leading to bearing failure. I am in the process of stripping the engine apart. Gazi came through on saturday morning (8/14/2010) to help me pull the motor and Donated a 96 SC300 2jzge engine just in case I need to replace the Crank Shaft & Rods.
#457
Crank & Rod Bearing Pictures
A Few Pictures of the Crank & Rod Bearing.
You can see the damage to the rod bearing and scoring of the Crank Journals in the pictures. The plan is to reuse the 2jzgte Block.
1 • Hot Tank the Block
2 • Hone the Cylinders
3 • Deck the Block
Use the 2jzge Crank & Rods as they were in perfect shape when removed.
4 • Hot Tank the Crank & Rods
5 • Polish the Crank Journals.
6 • 2jzgte Block
7 • 2jzgte Pistons
8 • 2jzge Crank & Rods
Everything is at "Lab Machine" being worked on.
3 • Deck the Block
6 • 2jzgte Block
7 • 2jzgte Pistons
#459
Kenny that's funny how we was talking on the phone about your block!!! lol the table just turned BHG caused by OVB and Crank Walk lol.
Boosted 7more LBS than my car was tune for.
