Yes it will not work because when I replaced AliSC3 Cylinder HG, he rented that tools so i can replace his Valves stem seals but i didn't work and i wasted about 2 hours messing with it
I will ask Slow_sc3 to post some pics of his compressor it's the same one i had
or you can just PM him let me know.
quickGS300 it works once I use the PVC tubing I made. I just finish reinstalling the Valve Spring and place the 2 Keepers around the Valve Stem
Adapter, for installing Tial 44mm (V44) Wastegate onto a manifold flanged (or other location flanged) for 35mm, 38mm, delta-gate, evolution, smartgate, or other 2 bolt wastegates. Low profile. Use with 2X 8mm x 25mm high strength hex bolts. Fully compatible with original Tial supplied wastegate v-band clamp. 3D CNC Machined from 1 pc. solid carbon steel. Note: Does not include an adapter for the outlet side of the 44mm wastegate.
There was an issue with the Wastegate Flanged Mounting Adapter. The studs were touching the V-Band Clamp which left no room for the Nut to be installed. AL the Welder came through again.
and why paint everything? the paint is going to dull and/or chip off within a few months of driving. (been there done that)
I can't help myself. I looks much cleaner. All metal that are painted are going to get Powder Coated after I decide on Color. All Plastic are going to be Hydro-Dip’s Water Transfer Printed also after I decide on color.
