Build Threads Details on Club Lexus SC owner vehicles
IT's Here 2jzgte vvti & Garrett GT3582R
Old 01-08-11, 01:10 AM
  #541
TURBO819
TURBO819's Avatar
Default Clutch Slave Cylinder.
I misplaced a part for the Clutch Slave Cylinder so I got a new one from Driftmotion along with their Full length clutch hose for W58 transmissions.
Full length clutch hose for W58 transmissions 120deg ends with 10x1.25 threads.
Old 01-08-11, 01:17 AM
  #542
TURBO819
TURBO819's Avatar
Default Phoenix Systems Reverse Fluid Injection Brake & Clutch Bleeder
Phoenix Systems Reverse Fluid Injection Brake & Clutch Bleeder. I purchased this so I don't need to bug my wife anymore for help with bleeding the Brake or Clutch
V-12™ The Professional Economy Model Brake Bleeder
The V-12 is the second most popular tool in the Phoenix brake bleeder line. It performs just like the MAXPRO™ and it has no problem making a short snack out of tough to bleed hydraulic systems.
It is ideal for the technician that bleeds systems two or three times a week (as opposed to two or three times a day like the PRO).
The easy to use V-12 provides a smooth pump action and a rubber grip for increased comfort and handling. It is made of high strength Zytel-nylon, offers a 12 ml stroke and is designed for light to medium use.
The V-12 lnjector is designed to inexpensively perform RFI, vacuum/pressure bleeding and master cylinder bench bleeding.
The V-12 is a redesign of the V-10 Injector. It has a smaller piston diameter that provides high hydraulic advantage. The V-12 can develop 125 psi, with comfortable hand force. The V-12 has improved ergonomics with a cushioned grip. To increase functionality a quick coupler was integrated into the end cap and the dosage adjustment was simplified.
The V-12 was also designed to be compatible with all types of brake fluids including D.O.T. 3,4,5 and synthetic blends.
The handle and body are made of high strength Zytel (glass reinforced nylon) which imparts metal like strength while retaining light weight comfort. The V-12 ergonomic design is compact and comfortable to use.
Old 02-08-11, 07:12 AM
  #543
TURBO819
TURBO819's Avatar
Default Battery Relocation.
Battery Relocation.
Old 02-08-11, 07:13 AM
  #544
TURBO819
TURBO819's Avatar
Default Fuse Box Relocation
Fuse Box Relocation.
Old 02-08-11, 07:41 AM
  #545
cartmill
cartmill's Avatar
invest in some heat shrink. all that electrical tape on that big (important) battery cable is ghetto.
Old 02-09-11, 05:47 PM
  #546
Li Ls4
Li Ls4's Avatar
awesome work man, cant wait to see this car finished
Old 02-12-11, 10:21 AM
  #547
TURBO819
TURBO819's Avatar
Default 3/8" Heat Shrink Tubing
I picked some up yesterday. I think it's 3/8" Heat Shrink Tubing
Old 02-12-11, 10:32 AM
  #548
TURBO819
TURBO819's Avatar
Default Few Clips
I ordered a few Clips that needed to be replaced due to Under Hood Temperature / Age.
Housing, Connect (90980-11246 ) Coil Pack x 3
Housing, Connect (90980-10947 ) Cam Sensor x 1
Old 02-12-11, 10:38 AM
  #549
TURBO819
TURBO819's Avatar
Default Denso (5311) IK24 Iridium Spark Plugs
Denso (5311) IK24 Iridium Spark Plugs.
I decided to try these out.
Old 02-13-11, 03:04 PM
  #550
Cleanshots
Cleanshots's Avatar
forget the heat shrink pick up some rescue tape. http://www.rescuetape.com/ its way better!
Old 02-13-11, 04:15 PM
  #551
cartmill
cartmill's Avatar
AKA "rubber tape."
i wouldnt recommend that with smaller gauge wire, as you have to pull/stretch that tape to get it to adhere to itself..
but for big battery cable, that would work well.
heatshrink still looks better, and works just as well
Old 02-14-11, 09:40 AM
  #552
TURBO819
TURBO819's Avatar
Default She Is A live
She Is A live. It's running on the MKIV Supra 550's Injectors without the AEM F/IC Fuel Ignition Controller because I had to send the Patch Harness to Dr.Tweake to make sure he wired in the MAP Sensor . The SYNAPSE SYNCHRONIC BOV BLOW Off VALVE was sent back to SYNAPSE for their upgrades. I also need to stop by the Toyota Dealership to pick up O-Ring Gasket for the water neck.
http://www.youtube.com/watch?v=bqZdn-yfYTs
Old 02-14-11, 09:50 AM
  #553
kez
kez's Avatar
CONGRATS dude on the sucessful swap shes a beaut
Old 02-14-11, 10:49 AM
  #554
Rising_Sun
Rising_Sun's Avatar
Congrats Kenny! Now we need to get together and "compare" notes.
Old 02-14-11, 12:55 PM
  #555
stockhatch
stockhatch's Avatar
Congrats on the resurrection! I hope it behaves for you longer this time. Let us know how that log manifold works out for you.
Quick Reply: IT's Here 2jzgte vvti & Garrett GT3582R
