Build Threads Details on Club Lexus SC owner vehicles
IT's Here 2jzgte vvti & Garrett GT3582R
Old 10-14-08, 04:30 PM
  #76
TURBO819
TURBO819's Avatar
Originally Posted by RikTT
Kenny ..I got what you need!
Like i said before i had most of those things you neded that i still have or may have discarded already. Glad that you got that ecu-uncross your fingers now !! G L with the build
START LOOKING FOR THAT SINGLE
I got the Supra TT SMIC pipes & Hoses coming in by weekend. I am trying to decide what to do about the Fuel Return Line. What do you think about this Fuel Kit from Summit????????????????????
http://store.summitracing.com/partde...5&autoview=sku
Old 10-15-08, 10:14 AM
  #77
Brownmagic
Brownmagic's Avatar
Ohh man Kenny
This is going to be sweet.
Can't wait till next week.
Old 10-16-08, 05:14 PM
  #78
RikTT
RikTT's Avatar
Ok cool. I found everything you needed as pictured above but i guess you got another set.. Good deal. Scratch that off the list !
That fuel return line/kit is decent for the price.. Not sure what you want to do as far as running an aftermarket FPR.. You can run the stock rail and tap that to accept an AN fitting to connect to the FPR and mount it somewhere then hook that return line set up straight to the FPR. Something to consider (not really needed for stock like). You can also run the stock rail/fpr with a fuel hose connecting to the -6 return line kit via -6 barb fitting. Not sure if you plan on sticking with stock boost.
That line should be long enough by the time you worm it through and neatly secure it as i did ( keep in mind that i have mine ended & attached rear lower firewall). Also look into a fuel line dampner bypass.
Old 10-16-08, 07:16 PM
  #79
TURBO819
TURBO819's Avatar
Default Good Looking Ricky
WoW, Ricky that's alot of things to consider. For right now I just want to get this engine in before the weather gets cold & make sure the engine is 100% & the ECU that I got does not the IMMOBILIZER. If it has the IMMOBILIZER I would need to have it RE CHIPPED. So you can see why I want to at least get the engine in and get her started. I think for now I am going to use the Stock Rail / FPR with a fuel hose connected to the -6 return line via -6 barb fitting. As for BOOST. I am going to stick with the stock BOOST. I am not going to be driving it over the winter(once a week if the weather is good). And try to save some fund for the second round of fuel Upgrades.
1. Aeromotive Fuel Pressure Regulator for. Part # Aero 13-101 / 9 MK4
2. Fuel Line Dampner Bypass
3. USDM 550's Injector & Resistor Box
You know that I am going to hit you up if I have any question so be on the look out. I am going to try to pull that engine on MONDAY if the weather is GOOD. Thanks for all the infomation.
Old 10-18-08, 11:05 AM
  #80
RikTT
RikTT's Avatar
No problem.. I can see getting it in and running fine is primary.That Ecu seems to be the concern. Well, you can do all those fuel upgrades once motor is in but like everything else its easier when out to manuver.
So there goes my "single" upgrade plea chance
Old 10-21-08, 04:52 PM
  #81
TURBO819
TURBO819's Avatar
Default Two Days
Well it's been a long Two Days but I got it in there. One day to remove (2jzge vvti). One day to install (2jzgte vvti)
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-191115.jpg
Old 10-21-08, 04:55 PM
  #82
TURBO819
TURBO819's Avatar
Default Fuel Return Line
Summit Fuel Return Line (SUM-PUMPKIT1)
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-191114.jpg
Old 10-21-08, 06:02 PM
  #83
Curry
Curry's Avatar
Awesome work kenny!! YOU ROCK!!!
Old 10-22-08, 10:03 AM
  #84
1siksc
1siksc's Avatar
nice, hope you didn't smash and brake lines, and purple water pump!???
Old 10-22-08, 01:05 PM
  #85
TURBO819
TURBO819's Avatar
Default I Hope Not??????????
I hope not for the Brake lines? That hard to get to with the engine there. I like PURPLE. I think that I am going to accent the Engine Bay with Purple. I think it would look good with the Green?? CThompsen what color is your SC300?? It look's like Royal Jade Pearl (6M2) ? I like that color better that the color I got now Imperial Jade Mica (6Q7).
Old 10-22-08, 01:11 PM
  #86
TURBO819
TURBO819's Avatar
Default Special Thanks
Special Thanks to $hogunn. He sent me a Free Walbro 255 Fuel Pump for the Swap. $hogunn GOOOOOOOOOOOOOOD Looking.
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-191119.jpg
Old 10-22-08, 01:14 PM
  #87
TURBO819
TURBO819's Avatar
Default A Few More Pic.
A Few More Pictures of the 2jzgte Installed
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-191116.jpg
Old 10-22-08, 01:16 PM
  #88
TURBO819
TURBO819's Avatar
Default A Few More Pictures @ 2
A Few More Pictures of the 2jzgte Installed @ 2
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-191117.jpg
Old 10-22-08, 01:18 PM
  #89
TURBO819
TURBO819's Avatar
Default A Few More Pictures @ 3
A Few More Pictures of the 2jzgte Installed @ 3
Attached Thumbnails IT's Here 2jzgte vvti & Garrett GT3582R-picture-191118.jpg
Old 10-22-08, 02:52 PM
  #90
Curry
Curry's Avatar
Start it up!!!!
Quick Reply: IT's Here 2jzgte vvti & Garrett GT3582R
