self built 800rwhp project sc300
#49
^^ i was going to put it under the head light but im going to put it where it was at but in an angle i think i seen it there before with this set up. but the manifold is great if it wasnt i would had just made myself one.
#56
yea that is about right it forces the exhaust to flow at a faster rate to one side of the turbo so it can spool up a lot faster. then when you hit the target boost that you have the valve set then it opens up and you don't lose your top end power because the flow will return to what it used to be. thanks a lot guys more pics to come soon thanks again for all the positive feed back.
#58
