self built 800rwhp project sc300
#107
That spooling valve is for use with a dual scroll turbo right. The way I'm under standing it is that it forces all of the exhaust through half of the turbo and the narrower inlet provides more pressure and spools the turbo faster. Then at a certain boost level it opens and doubles the inlet for better air flow? Am I 100% correct or missing something?
Also, if that is how it works, is it only good for launch control? OR can it be used to spool the turbo faster when moving? Like on a dyno.
#110
yea let me up date you guys sorry for being gone so long.
direct port nitrous
all the fab work on this car was done by me.only thin i didnt make on this car was the intake manifold.but every thing else i did.
direct port nitrous
#111
built block is on its way with custom pistons and other good stuff. Im building this car for a reason and one reason only and thats for the title worlds fastest sc300.so for the car at 24lbs on stock block made 780 with a th400 on 3200lbs car. we left boost there alone since she broke and max the igntion out. i just ordered the m&w igntion box and that will sloce the problem for the new motor this block is maxed out if this was a six speed it would be a little under 900rwhp so im happy for now. also the umbers were done on e70
#112
gl in achieving your goal. That is some nice work you did on your car
I remember seeing your build a while ago, carbon fiber doors, and do-luck rims right? and u got down to 3200 lbs?
#117
here is a teaser im ot done ill see if i ca do some 20psi pulls today because all i do i spin with the 18s and to cold to be out there putting on my 15 inch with 28 inch tires on.
http://www.youtube.com/watch?v=ore6H6chsDM
