Build Threads Details on Club Lexus SC owner vehicles
Project: 97 6-speed, SC400 supercharged 4.7L V8
Old 01-04-09, 04:22 PM
  #91
ScottURnot
ScottURnot's Avatar
Location: Sideways on the Yellow Brick Road! < Thats KS!
Here is what I am working on to help with equalizing air flow. First guys I will say, I am not an expert nor do I have a flow bench so this is a experiment that I will most likely never know the real out come.
I think the intercooler will help the air flow distribution so I intend to expand on that. The one issue I wanted to try and resolve was to get more flow to the end of ports with the intercooler installed. Since the manifold is cast from thick aluminum I thought I could take advantage of that and possibly make a channel to flow the air. This really improves the flow area where the intercooler sets so I hope it will help.
Here are some shots of the work so far.
Now for the centering of the air flow to feed these new grooves. As you can see below the Supercharger exits up front. I intend to block off about 1.75" of the intercooler on the bottom side to try and force the air to the center. If you see the small black marks on the intercooler in the first pic, that is where I intend to block it off underneath. The second photo shows the underside where I will tig weld in a block off thus centering the outlet. This block off late will be about 1/4" below the core. This also will in theory force the air to travel over all the intercooler. Any thoughts guys?
Old 01-05-09, 05:04 PM
  #92
SpinAll4
Former Sponsor - Cancelled
SpinAll4's Avatar
I like the porting idea, I would try to belmouth the ports as they go into the main chamber if there is enough meat to do so.
Old 01-12-09, 02:26 PM
  #93
OMD
OMD's Avatar
subscribed to another amazing build!
Old 01-15-09, 08:39 PM
  #94
ScottURnot
ScottURnot's Avatar
Making progress but nothing to really show at the moment.
Adjustable cam sprockets from Andrew at Richwood.
Old 01-15-09, 11:44 PM
  #95
ShakeyBone
ShakeyBone's Avatar
That has fun written all over it. Great job
Old 01-16-09, 12:06 AM
  #96
xirforever
xirforever's Avatar
ok so im not an engine buff at all, so help me out here. Because the 1uz has quadcams, and on each bank both the exhaust and intake cam are connected with 1 cam gear, adjusting it would change both intake and exhaust as the same time, right? Is this still beneficial?
Old 01-16-09, 04:21 AM
  #97
ScottURnot
ScottURnot's Avatar
Yes you are correct, if you read further up I had the seperation custom ground into my cams. These gaers are only to adjust the cams to the intended specs. I may buy a set of adjustable scissor gears if I find the need when I start degreeing my cams.
Old 01-22-09, 08:24 PM
  #98
ScottURnot
ScottURnot's Avatar
Decided to make my own bullet proof Urethene enging mounts
Here is a cad file of the stock one.
Now a cad file of the new one
Now a cad file of them over each other to show how they fit the stock mount envelope
Now some finished pics, They are wrinkle coat painted.
Old 01-22-09, 10:03 PM
  #99
ICONYQ
ICONYQ's Avatar
wow those are clean...nice job on those.
Old 01-23-09, 03:52 AM
  #100
lfrers
lfrers's Avatar
WTF Scott???? You an Engineer?
Old 01-23-09, 04:02 AM
  #101
ScottURnot
ScottURnot's Avatar
I used to get to do lots of Engineering stuff, Now I mostly manage the Engineering and sales department. I miss it, The only design work I really get to do now is on my own projects. Its not all bad.
Old 01-23-09, 06:39 AM
  #102
rdm20fan
rdm20fan's Avatar
I WANT ENGINE MOUNTS!!!!
When do you plan on displaying this bad boy for the world to see?
Old 01-24-09, 09:29 AM
  #103
TheRonTom3
TheRonTom3's Avatar
How harsh do you think those will be?
I could kind of see them vibrating the teeth out of your head.
Old 01-24-09, 11:00 AM
  #104
ScottURnot
ScottURnot's Avatar
I dont think they will be really harsh. They are still fully isolated. They are 1 1/2" energy suspension urethane so they should be more solid than rubber but still eat up the vibrations.
Old 01-24-09, 06:00 PM
  #105
SC400TT
SC400TT's Avatar
Scott, we are not worthy.... You know I am in for a set!!
Ryan
Quick Reply: Project: 97 6-speed, SC400 supercharged 4.7L V8
