Build Threads Details on Club Lexus SC owner vehicles
GTE swap rebuild thread into SC300
Old 08-01-09, 03:27 PM
  #166
slappy96
slappy96's Avatar
Default OK Sports Fans
Here's some pics of the swap complete and running...good. Pictures speak a thousand words.
Old 08-01-09, 04:52 PM
  #167
OMD
OMD's Avatar
that looks great man! great job, now that's how an engine build should be, don't forget to post up some vids off it running and burning rubber..
Old 08-01-09, 06:13 PM
  #168
YeA 2jZ
YeA 2jZ's Avatar
super nice man great work looks so clean like it came like that
Old 08-01-09, 08:07 PM
  #169
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Very clean...
Old 08-01-09, 11:21 PM
  #170
howat
howat's Avatar
wow...so clean!!
Old 08-02-09, 03:08 AM
  #171
BigManne
BigManne's Avatar
kick *** man
Old 08-04-09, 07:09 PM
  #172
slappy96
slappy96's Avatar
Originally Posted by tmf2004
Very clean...
Originally Posted by howat
wow...so clean!!
Originally Posted by BigManne
kick *** man
Thanks all for the kind words. She's running pretty good right now. Only issue I'm having is Transmission DTC codes 42 and 87. I think it's affecting the power delivery a little. Code 42 is the #1 speed sensor. Supraforums has a discussion about how this is related to the odometer circuit cold solder, but I don't know if it applies to SC's. Code 87 I cannot find. Any help appreciated.
Slappy
Old 08-04-09, 11:51 PM
  #173
onejapman
onejapman's Avatar
for the aristo tranny to fit, did u just use a sc400 drive shaft and flange? was there any other required hardware?
Old 08-05-09, 01:59 PM
  #174
slappy96
slappy96's Avatar
Only thing you didn't mention was the tranny crossmember from the SC.
1. SC400 DS both halves
2. Rubber donuts on diff side and tranny output side (should still be on the SC400 DS)
3. SC400 output flange
4. SC300/SC400 tranny crossmember
5. A 30mm deep socket to remove the output flange nut.
Enjoy
Old 08-06-09, 05:31 PM
  #175
parnzen
parnzen's Avatar
what did you do about the ecu? ive heard that if you cant use the ge ecu or the jdm one off of the gte. does dr tweak change the ends on the harness to fit?
Old 08-07-09, 01:01 PM
  #176
slappy96
slappy96's Avatar
The Jdm engine comes with the ecu that belongs to it, so all that is reqired is appropriate splicing with the sc harness so the body plugs marry up. A three foot extention is required for JDM right hand drive.
You can't use the GE ECU with a GTE engine without serious modification. Hope that helps.
Old 08-07-09, 07:16 PM
  #177
TURBO819
TURBO819's Avatar
Default She's Alive
She's Alive. This is good news. Join the GTE Poll
https://www.clublexus.com/forums/per...your-hood.html
Old 08-10-09, 07:45 PM
  #178
SimplyZBes
Masterhater
SimplyZBes's Avatar
Thumbs up SimplyZBes aka The Master Hater
I am going throw my two cents in. Your project and your outlook was brilliant! I love the way you did all your engine work on a stand and remained patient. Everything turned out as planned and it looks perfect.
Old 08-10-09, 07:53 PM
  #179
SimplyZBes
Masterhater
SimplyZBes's Avatar
Old 08-15-09, 07:49 PM
  #180
slappy96
slappy96's Avatar
Thanks man. Hopefully it helps others out as well.
Quick Reply: GTE swap rebuild thread into SC300
