GTE swap rebuild thread into SC300
#52
Update
Sorry it's been a while
Got my wiring harness back from Dr. Tweak and it's money!!! Pictures to follow.
Things I'm waiting on.
1. Igniter
2. Flex plate (bent the other one getting the crank bolt off)
3. Crank Pulley
4. Engine mounts/brackets
I think I'm going to swap out the USDM turbo's I got from Stu Hagen for the JDM/GT28ish ones. Some subtle differences in the JDM turbo piping and the fact that I already have a JDM manifold have talked me in this direction.
1. Igniter
3. Crank Pulley
#53
#54
Nice to see updates. Aren't the Japanese stock twins the weaker ceramic ones? could be wrong. If you pay the shipping you can have my flexplate for free (assuming I don't bend it when I take it off tomorrow).
#55
If it's a GTE flexplate then I'll do that. However, I thought the GE flexplate would be the same and it's not. Holes are like 2-3mm offset.
#56
Update
I feel as fickle as the wind. So...now I'm keeping the hybrid US twins. Found a crack in the JDM turbine housing and I don't want to deal with a custom downpipe. Anyway, pics of the engine and wiring harness below. Waterpump on.
#57
Keep us updated, im really interested in that GT28 hybrid setup.
#58
How different are the USDM turbos compared to the JDM ones? I always thought that the turbos were essentially the same construction other than the ceramic blades. Also the JDM manifold and USDM manifold are completely different as well?
What I am going with are the USDM hybrids that I currently possess. Minor upgrade, but better bearings and a 12 blade compressor/ vice 10 for OEM.
#59
Update
My father died last Sunday so the car has been on hold. Things are different, but the SC is good to keep me busy.
Finally got everything squared away with the turbo's. Stu Hagen is the man for providing me with everything I needed for USDM setup.
Waiting on motor mounts to come in. I've got to get them on before I can start piling a lot more on the block.
#60
Sorry to hear about your loss. My condolences.
Your swap is looking fantastic. It's nice to do the complete rebuild. I've done that before, and it's a great feeling once you hit the key.
