Build Threads Details on Club Lexus SC owner vehicles
GTE swap rebuild thread into SC300
Old 06-19-09, 08:08 AM
  #121
slappy96
slappy96's Avatar
Originally Posted by BigManne
Tupelo. what about you?
Meridian! Never been to tupelo
Old 06-19-09, 08:16 AM
  #122
slappy96
slappy96's Avatar
Originally Posted by shern
May I ask the part number for the power steering reservoir?
44360-24042 And it costs three times what it should!
Old 06-21-09, 08:26 PM
  #123
BigManne
BigManne's Avatar
cool. your not missing much.
Old 06-24-09, 09:28 AM
  #124
slappy96
slappy96's Avatar
Default THE Engine is IN! Finally
OK. Got the engine in. What an incredible pain in the butt. About 90% of the pain was due to my work area and some mistakes but hopefully guys can learn from it. Pics soon.
Lessons learned.
1. A smooth concrete driveway or tall garage is key. I knew I would run out of headroom. Rolling a 650lb engine around on a pebble/concrete mix driveway is less than optimal. I knew it was coming, but I had no other option.
2. An engine leveler is only good if it keeps the engine level laterally as you change the pitch longitudinally. Took three attempts and it wasn't until I jacked the tail of the transmission up that I could get the engine mounts to line up.
3. All 2JZ Flex-plates do not match all 2JZ torque converters. I have three and I know at least two of the flex plates are 2JZGTE. I HAD to use the original flex plate that was matched with the torque converter. The other was about half a bolt hole width off (vertically-not hortizonally). Talk about a heart dropping moment. It's the little stuff that gets you. Anyway, at least I figured it out prior to putting the engine in. I had to rip the tranny back off and swap the flex plate.
4. Putting the torque converter on requires patience. No amount of aligning helped. I saw the keyways vividly on the trans shaft and converter, but still had to just keep stabbing and spinning. 45min-1hr just doing that.
5. Trans cooler hard lines blow. I mangled mine so now I'm going stainless steel braided with an fittings.
6. The SC400 driveshaft works perfectly....well at least it looks that way. I won't be running for a little bit. Taking a 17+year old driveshaft off with no transmission to hold it is quite an adventure. E-brake isn't strong enough to hold that kind of torque through the diff.
There is more to come but I'm glad that part is done.
Old 06-24-09, 10:08 AM
  #125
YeA 2jZ
YeA 2jZ's Avatar
keep on truckin man your almost to the end. nice work keeps us posted with pics i'm really feeling your thread
Old 07-05-09, 04:14 PM
  #126
slappy96
slappy96's Avatar
Default UPDATE. Pics.
This will bring most everything up to date picwise. Now I'm just waiting on the transmission output flange adapter from Aliga. That would have been nice to know prior to putting the engine in, but I took the driveshaft out and got it off.
Going in....engine levelers are cool, but mine leans left laterally as you bring the tail of the engine up. Not cool.
Old 07-05-09, 04:23 PM
  #127
slappy96
slappy96's Avatar
New Supra sway bar
Igniter on the right...Crazy
SC400 Hyd and power steering cooler. This is unnecessary, but I did it anyway. I've got a spare little radiator if I ever want more oil cooling.
SMIC
This is my answer to going from stainless steel braid to 3/8" nipple on the auto tranny cooler in the radiator.
Supra endlinks for the new sway bar. Lol, the only thing on my front end that is not supra is the UCA.
Old 07-05-09, 04:26 PM
  #128
slappy96
slappy96's Avatar
OK. Now that I've posted some pics I just want to say I know everything looks dirty as crap. I've put a lot of spit and polish off till the end so bear with me.
Old 07-05-09, 04:46 PM
  #129
runt
runt's Avatar
Great write up just read all 9 pages you're very thorough I bet you can't wait to actually drive this thing.
Runt
Old 07-05-09, 11:42 PM
  #130
wheels 2
wheels 2's Avatar
opppppppppppssssssss.......
Old 07-05-09, 11:44 PM
  #131
wheels 2
wheels 2's Avatar
Sorry, I should have been more clear. These are not bone stock. They are upgraded. Same upgrade that Stu has on his car. 20psi/450pump gas. TT auto can't take anymore than that.
What do you mean by? (TT auto can't take anymore than that)
Old 07-06-09, 07:04 AM
  #132
slappy96
slappy96's Avatar
450hp~ish seems to be the point around which the auto-tranny starts to give up if you're hard on it. I know there are exceptions, I just wasn't planning on gunning for more hp than that with the stock TT auto.
Old 07-06-09, 10:07 AM
  #133
jadu
live.love.laugh.lexus
jadu's Avatar
slappy, I may have missed it on your thread, but did you do the wiring? JDM wirring correct?
Old 07-06-09, 01:14 PM
  #134
slappy96
slappy96's Avatar
No man. I wanted to, but Dr. Tweak did my harness. Just looked to be a little much seeing as how I've soldered about three things in my life. JDM Aristo merged with SC300 harness.
Old 07-06-09, 03:28 PM
  #135
wheels 2
wheels 2's Avatar
OH ok.I have got a the stock tranny in my mk4.And I was making 500 and some odd numbers to the wheels and it has held up for a long time with beating on it.
I have 128,000 miles on it and it just started to go out.
Quick Reply: GTE swap rebuild thread into SC300
