Build Threads Details on Club Lexus SC owner vehicles
B-ver's Build Thread
Old 04-23-09, 02:26 PM
  #226
LEX_MAN
LEX_MAN's Avatar
Originally Posted by BattleVer
I was originally going to T the rear in the same place since it runs double lines and I already put those back in, but after looking at the rear again, decided to just T off the rear and I'll take the other rear brake line out when the fuel lines go in.
Great minds think alike
Old 04-23-09, 08:37 PM
  #227
BattleVer
BattleVer's Avatar
Originally Posted by dorikaze
very nice progress!
im suprised you didnt cut out the spare wheel well and make it flat.
I'm still thinking about doing that.
Mishimoto sent me one intercooler, I took a look at it and was like, its too small. Emailed them back and asked if it was possible to get another one. "What for" they ask. "I'm going to try and double it up, looks too small for 1000hp, I'll show pics, I promise", Mishimoto "Ok, send Alex one more." So they sent me another intercooler, this time in black.
So, which way to make this thing bigger, was thinking first of making it double thick, put one infront the other since alot of the supra's run like 4" thick cores. Then thought of going double as long since the front of the car is so wide, problem was the frame rails are a bit low and would have to cut those out. Then was thinking of making it double tall, like the size of the rad. Then a friend was like "just make it taller" so yeah, here is how it went.
start with 2 intercoolers...
Cut the end tanks off the black one.
Pic of the inside...
Then trimed the black one up the the first core area. Cut the other end tanks but left the hose ends still on it. Then measured how much space I had in the front of the car and took a chunk out of the aluminum core. You can see it sitting up there by itself, and welded up the corners.
As you can see, its now the full height of the rad, kinda like diesel truck style. Still need to trim down a few things like that hood latch area and the high beams, then it will be nice and tight in there.
I just hope there will be enough clean air to keep the water temp down now that I filled alot of it up with this thing. Still need to finish up the end tanks but probably do that when its time for the pipeing.
Thanks Mishimoto!
Old 04-23-09, 09:06 PM
  #228
rwdanthony
rwdanthony's Avatar
i think you should, you can also mount the fuel cell lower if you just make it how you want. but you would have to throw in some reinforcements as you might lose some chassis rigidy from losing the 3-dimensional layout structure in that area.
Old 04-23-09, 09:12 PM
  #229
cazman
cazman's Avatar
I used to use an 800x300x100mm core (im aussie so its in mm haha)
I did an under the headlight conversion on both sides which Ive never seen before too. The stock setup is terrible. Any plans on what your doing with yours?
I had overheating problems too, no bonnet vent. I used a few thermo probes and concluded the cooler was just blocking too much air, So i changed my setup earlier this year.
Cooler was great though
Old 04-23-09, 09:16 PM
  #230
BattleVer
BattleVer's Avatar
Caz, what rad did you have?
Old 04-24-09, 07:07 AM
  #231
cazman
cazman's Avatar
an ebay china one, I think it was 700x330x32mm
I am now using a much thicker PWR one.
I dont ave many installed pics of it now, its in the bin
I am now running this puppy, a simple 22x19x2.36" V8 style PWR radiator
Old 04-24-09, 07:40 AM
  #232
ucfa4
ucfa4's Avatar
Nice build now lets see it drift. I like the fact that you did it right.
Old 04-24-09, 09:01 AM
  #233
TheKevin
TheKevin's Avatar
i just went thorugh all 16 pages. very nice build!
Old 04-24-09, 12:34 PM
  #234
GZZ-TT
GZZ-TT's Avatar
Alex, gonna paint that intercooler one color or leave it as is Black/Metal?
Old 04-24-09, 02:04 PM
  #235
vinh
vinh's Avatar
nice job on the intercooler!! I've only seen one other car do something like that and it's this car
Old 04-25-09, 12:19 AM
  #236
BattleVer
BattleVer's Avatar
Thats a cool double long setup.
Uzz, I dont know yet if I should black the whole intercooler out. When you put the bumper on, you only see the aluminum part really.
Picked up the brakes today from Rotora and did a quick test fit.
Then helped the guys clean shop at G-Dimension. Having a garage sale this weekend (4/25 and 4/26) from about 10 am till about 5. Tons of sr20det parts and a bunch of random things. I'll be there on sat for sure, dont know about sunday yet. If your not doing anything and want to check out the car, the address is 817 lawson st, 91748.
Old 04-25-09, 01:10 AM
  #237
TougeSC3
TougeSC3's Avatar
Alex something tells me you are gonna run into a lot of heating problems with that setup. That custom intercooler is gonna be way to tall and create a lot of lag on whatever turbo you plan on using to make 1K horses. Especially if the car is gonna be sideways 95% of the time you might want to reconsider your setup. Did Mishimoto not have a thicker/ want to send you a thicker intercooler? Hell you might have been alright with the original one.
Old 04-25-09, 06:52 AM
  #238
GZZ-TT
GZZ-TT's Avatar
If you made the high beam holes into air intakes you'd have some much needed flow.*
Old 04-26-09, 09:21 AM
  #239
Biggu
Biggu's Avatar
Alex, i dont think you will have much termal issues with water temp. Drifting my car yesterday at 87 degrees outside with my stock radiator and stanza fans my temp never raised one bit. granted your making more power then me but i dont think you will have a issue one bit.
Old 04-26-09, 09:51 AM
  #240
BattleVer
BattleVer's Avatar
The only way we are going to know if this setup is going to work is to get the car done and simply test it and see how the temps end up. I can always redo the intercooler, thats not much of a problem.
Quick Reply: B-ver's Build Thread
