Biggu's engine refresher build thread.
#49
other news, got my drain flange
![](https://i18.photobucket.com/albums/b107/2zumeunos/SC300/winter%2009/DSC_0472-1.jpg)
got my oil filter relcation kit figured out.
![](https://i18.photobucket.com/albums/b107/2zumeunos/SC300/winter%2009/DSC_0474.jpg)
Power steering res came in
![](https://i18.photobucket.com/albums/b107/2zumeunos/SC300/winter%2009/DSC_0477.jpg)
![](https://i18.photobucket.com/albums/b107/2zumeunos/SC300/winter%2009/DSC_0475.jpg)
got all my fittings for my power steering to convert to AN. i just need to pick up the flange for the inlet on the power steering pump which i had a -10 an fitting added to.
![](https://i18.photobucket.com/albums/b107/2zumeunos/SC300/winter%2009/DSC_0476.jpg)
and lastly got my IACV block off plate made:
![](https://i18.photobucket.com/albums/b107/2zumeunos/SC300/winter%2009/DSC_0478.jpg)
im planning on cleaning the whole engine bay this weekend. so dont mind the dirt and grease.
#56
not really, its just been sitting as you see there. Priority in life I suppose if thats what you want to call it. I need to get some of my bills paid down before i go putting a bunch of money into this. I need to go make a list of the stuff that still needs done so i can get to work on it again. I know for sure i need a clutch, fuel rail, injectors, wastegate, radiator, all oil/water lines. downpipe and screamer pipe.
#58
alright im tired of this car sitting around so im starting to get moving again.
over the last few days ive ordered a few things and changing the plan yet again. In order to get the car going and driving ill just get a capable single disk clutch and buy the twin disk later. I am going to run E85 in the car now.
so Ive ordered all my fittings for the turbo, got a oil feed line for the turbo, water lines all figured out, im going to go to get a -6 fitting to tap into the water neck for water, I ordered a soarer shifter extension, Im also going to remove the GE oil filter perch i installed and thread the filter adapter directly to the block.
Im also thinking about getting the intake manifold ceramic coated to help with heat but im not quite sure. I should be ordering a clutch this week and possibly fuel rail and injectors.
I think the injectors will be 1100cc or 1600cc not quite sure yet.
