Build Threads Details on Club Lexus SC owner vehicles
Biggu's engine refresher build thread.
Old 08-30-10, 12:50 PM
  #61
Biggu
Biggu's Avatar
Originally Posted by JohnMatt
What's the size of the hotside of your turbo? Everything looks great
the hotside is .84 twin scroll and 3" vband
Originally Posted by TURBO819
Any information on your Oil Filter Relocation Kit. What company is it from? Is it a Billet piece?
the oil filter adaper is by derale part number 15703
http://www.jegs.com/i/Derale/259/15703/10002/-1
the oil filer mount is by earls, billet temp a cure filer mount 2178
http://www.jegs.com/i/Earl%26%23039%.../2178/10002/-1
I show jegs because they are down the street from me and that's where i got it. I am not using a thermostat of the oil also becuase my car is pretty much track only and I get enough time to let the oil warm up however derale makes one for $40 some bucks that should work
http://www.jegs.com/i/Derale/259/25719/10002/-1
Old 08-30-10, 12:53 PM
  #62
Biggu
Biggu's Avatar
also the more research I do on clutches it looks like I shouldn't bother with a single disk and just go to a twin. Im thinking this setup should be quick spool and might be to much for a single disk.
Old 09-02-10, 09:17 PM
  #63
Biggu
Biggu's Avatar
heres some update pictures. I got everything i needed to convert my Supra R154 to a soarer style using toyota OEM parts, figured out my oil feed, Got all my fittings for my turbo, figured out my oil drain line, got my water neck oem water feeds welded shut, tapped and fitted a water feed for the turbo on the water neck and probably a few other things.
Im going to be removing the OEM oil filter perch and mount directly to the block. This shot is just to show the oil feed from the oil lines. I am going to need to buy a bunch of fire shielding for all my water/ oil lines. bah.
Old 09-02-10, 09:55 PM
  #64
94_soarer
94_soarer's Avatar
PM'ed!!!!!!!!!!!!
Old 09-03-10, 12:18 AM
  #65
TroySC300
TroySC300's Avatar
VERY nice! I love watching stuff like this come together. Keep it up
Old 09-03-10, 02:21 AM
  #66
vietunit
vietunit's Avatar
Coming along very nice Biggu!
Can't wait to see it all together!
Old 09-03-10, 04:14 AM
  #67
stockhatch
stockhatch's Avatar
Very awesome upgrades! Out of curiosity, is there any particular reason you don't use the factory oil galley to feed the turbo?
Old 09-03-10, 08:12 AM
  #68
Biggu
Biggu's Avatar
no real reason, this is a 2jz block and its just easier to piggy back in the line.
Old 09-03-10, 08:31 AM
  #69
stockhatch
stockhatch's Avatar
Oooooooh Duh. So the 2JZ NA block does not have the feed bosses? I totally forgot this is a NA block.
Old 09-03-10, 08:34 AM
  #70
stockhatch
stockhatch's Avatar
Ok, looking at the pics, it appears the bosses are present, but not drilled and tapped. Good to know.
Old 09-03-10, 11:26 AM
  #71
Bcasey
Bcasey's Avatar
looks great subscribed
Old 09-07-10, 06:42 AM
  #72
Biggu
Biggu's Avatar
did a little work on the car this weekend but it was mainly cleaning, tapped the waterneck and put the fittings in place. washed the car down to get the dust off, cleaned the engine bay. removed all water heater lines, tested the brakes, ran a power cable to the trunk, put the wiring harness in the driver fender away from the tire and tried to degree the cam but failed again.
heres the cams at TDC, to me it just doesent look right it seems the intake and exhaust would be closed completely.
everything is zero'd out.
Old 09-07-10, 03:09 PM
  #73
JohnMatt
JohnMatt's Avatar
Nothing helpful but what assembly lube was used for the cams?
Old 09-07-10, 11:17 PM
  #74
OneJay
OneJay's Avatar
Is there any way you may have installed your cams/gears 180º from where they are supposed to be? It looks like that is where they should be. ie., exhaust valves have just closed, and intake valves are about to open.
Old 09-08-10, 06:17 AM
  #75
Biggu
Biggu's Avatar
well after further research on the cams they are correct. ive talked with may toyota "experts" and they say that its right. I also looked at an old picture of my stock cams and its good.
Johnmatt the assembly lube was redline assembly lube. ill probably be taking off the caps and adding some more since its been sitting so long and im starting to move the engine more and more.
Quick Reply: Biggu's engine refresher build thread.
