Carfreak's CLEAN SC300 5 speed build shooting for 500WHP+
1JZ Single SC400
I cant rememeber when I saw that clean of interior of grey. Thats what mine looked like until I saw Scotturnot interior's, then on with the transformation to black and grey. Car looks clean, and good luck with your build.
Very clean interior. btw since your looking at 500whp. why didnt you just keep the 6sp tranny. I understand selling the gte motor because it looked like a hack n slash job and your last car looked mistreated badly with interior/exterior wise so i understand why you got rid of it. Was the 6sp bad also because it would be perfect for your power goals with this one, or you just going go R154?
This is the note that was on the bill
"GUEST STATES THAT CHECK ENGINE LIGHT CAME ON THEN STARTED TO OVERHEAT THEN WILL NOT START RADIATOR FAILED. SEVERE ENGINE OVERHEAT. HEADGASKET FAILED. CYLINDER HEAD EXTREMELY WARPED. DISASSEMBLED TOP END OF ENGINE. SENT HEAD OUT TO BE RESURFACED AND PRESSURE TESTED FOR INTERNAL CRACKS. RECONDITIONED VALVES/SEATS AND INSTALLED NEW VALVE SEALS ASSEMBLED ENGINE. REPLACED RADIATIOR. WATER PUMP. TIMING BELT. THERMOSTAT. IDLER PULLEYS. ALL HEAD BOLTS AND OTHER MISC GASKETS AND SEALS. CHARGED BATTERY. PRIMED FUEL SYSTEM. ENGINE WOULDN'T START. VERIFIED ASSEMBLY DIAGNOSED AND CHECKED CYL COMPRESSION. COMPRESSION WAS LOW ON 4 INSIDE CYLINDER SUSPECT STUCK RINGS IN PISTIONS DUE TO OVER HEAT. REMOVED CLYINDER HEAD AND INSPECTED CYLINDERS. OILED CYLINDER AND CHECKED FOR WIPING. RINGS APPEAR TO BE PERFORMING PROPERLY. INSPECTED CYLINDER HEAD AN VALVES. VALVES WERE NOT SEATING COMPLETLY. SENT HEAD TO MACHINE SHOP AGAIN. VALVES COULD NOT BE SEATED PROPERLY. THE HEAD HAS SUSTAINED TOO MUCH DAMAGE. LOCATED ANOTHER USED HEAD. STARTED AND OPERATED NORMALLY. ROAD TESTED AND VERIFIED REPAIR. CHECKED FLUIDS AND INSPECTED. ALL GOOD.
Thermostat - 25.97
Belt. Timing - 45.98
Pump assy. water - 277.09
Belt. V-ribbed - 99.99
Gasket kit Engine - 391.21
Bolt - 22.66
Washer plate - 1.74
Shim. Valve Adjus - 13.76
Idler sub assy. T - 111.82
Radpro rad radpro R - 254.88
Gasket. Water INL - 8.32
Plug Spark - 11.52
Bolt. w/ washer - 11.52
Stud. Hex Lobular - 9.06
Cap Sub-assy. Rad - 19.31
Antifreeze gallon - 38.39
Gasket Cylinder - 120.70
Seal. Valve stem - 8.06
Head 11035 - 800.00
Clip - 7.77
Gasket - 2.23
Guide Timing belt - 7.59
Job#1 Total parts - 2928.32
Job#1 Total Balor & Parts - 5606.32
Pressure test - 150.00
5W30 oil - 28.40
wow thats an awesome amount of work they did. must run like it has 5k on it! hows everything else on the car besides the engine? electronics working good? the only thing is that current fender gap is HUGE haha do somethin about that man
