Build Threads Details on Club Lexus SC owner vehicles
My Royal Jade Sports Coupe
Old 09-28-11, 10:49 AM
  #421
kez
kez's Avatar
ohhh yeah back in buisness,
ironic how you pull the scarface line and im literally watching a pablo escobar docu on HBO
highpull and burnout vids soon
Old 09-28-11, 12:16 PM
  #422
BAD954BOI
BAD954BOI's Avatar
is that a short shifter i spot??
of was the shifter just polished...???
lol
Old 09-28-11, 01:24 PM
  #423
94_soarer
94_soarer's Avatar
^^^ looks like a short throw to me :-)
Old 09-28-11, 04:58 PM
  #424
stockhatch
stockhatch's Avatar
Yeeeeeeahhh boyeeeeeee! LOL Nice find sir. True soarer/chaser R154 FTW
Old 09-28-11, 05:46 PM
  #425
94_soarer
94_soarer's Avatar
Thank you Sir...Just waitin on it to arrive!!
Old 09-28-11, 06:54 PM
  #426
Wicked SC
Wicked SC's Avatar
Congrats Nate!!
Old 09-28-11, 07:11 PM
  #427
94_soarer
94_soarer's Avatar
Originally Posted by Wicked SC
Congrats Nate!!
Thanks Rome!! Soon ima bring the SC back down n would love to take a ride with yall to the truck stop!!! Hands Down that was the best Jerk Chicken Ive ever had.
Old 09-29-11, 05:44 AM
  #428
DoomLight
DoomLight's Avatar
Niceness! Need to dyno it ASAP! How much was that clutch kit?
Old 09-29-11, 07:08 AM
  #429
94_soarer
94_soarer's Avatar
Yessir, ima jus leave it on hi boost in ride for now, but once my tuner & I have some free time, i will be taking a trip back to the Dyno at STP in South Florida, to Crank up te boost & retune since we dial'd it down when tunning so i dont kill my W58, and you see that didnt work..lol
The clutch kit goes for about $715-800 depending on where you buy it from
Old 10-05-11, 07:09 AM
  #430
99SC42
99SC42's Avatar
get a stock flywheel the LWF are too noisy, rattles, i'll never use them on my cars or any other project...
***Some the clutch kit doesn't come with the TB and shims you will need to order them from toyota and make sure you buy the shims also this happened to me and my car sat on jack for 4 days from saturday till tuesday.
Tq the flywheel to 75lbs and it's be fine, then mount to the pp and line up the dowel pin from the FW to the PP , and the holes on the pP matches will the fw once you do that just use a marker .
Mark the flywheel and PP on the side just cross a line from the PP to fw on the side ..Why do this because it will make your life 5000 times easier.
then slide the PP on the spline and then the disc make sure you look at the disc it will say FW side.
mate the trans to the block , line up the dowel pin with the bellhousing then install 2 bolts to hold the trans in place.
now you have to bolt up the PP to the flywheel, remember i told you to draw a line on the PP and FW just look for those lines on the fw and PP line them up and bolt the pp to the fw .
if you didn't mark them up ..you will have to sit and keep turning the pp to make with the fw which is not fun doing when you are on your back!
tighten the 6 bolts on the PP in sequence i tq them to 14 lbs .
if you do it this way it actually take you 30-45 to install the trans instead of 1:30 to 3hrs.
The rest is like doing a W58 swap, change your diff before you start boosting hard! 4.10 ratio doesn't not match your trans and setup.
Fluid i used redline mt90, Royal Purple 75w90 .
make sure the dust shield on the back off the trans doesnt have any bend in it because the shield on the driveshaft will be scrapping it on the inside and it will be making stupid noise lol , it happened to me once car ran great on the dyno as soon as i rolled off the dyno i hear a lood scrapping noise in my tunnell.
You got my number hit me up if needed..
Old 10-05-11, 08:36 AM
  #431
94_soarer
94_soarer's Avatar
Hey i think my clutch kit came with the Pilot & throwout bearing, check the pics
Old 10-05-11, 09:19 AM
  #432
Boboridesb
Boboridesb's Avatar
the past hr i been going threw ur thread...i made it to hear. page 23, where i decided i seen what i needed to, relieved myself and cleaned up after watching ur pull vids, and am now going to commit to go through the rest of the pages. i love your car man!
Old 10-05-11, 09:25 AM
  #433
99SC42
99SC42's Avatar
^ Ok kool then just get the shims and snap ring. Yeah i got the pics !
Old 10-05-11, 11:14 AM
  #434
94_soarer
94_soarer's Avatar
Lol thanks sir!
Old 10-10-11, 09:46 AM
  #435
94_soarer
94_soarer's Avatar
Update guys!!!
Well guys the sc is no longer trannyless, I got everything put together, but ran into alil issue with the driveshaft, it was alil too long, so I said what the hell...ill jus take it to a local driveshaft shop n have them make me a 1 piece driveshaft..
No pics atm, but once the driveshaft if done and im installing it ill take pics of everything..
Quick Reply: My Royal Jade Sports Coupe
