★★★★★Passnu2 Build Thread★★★★★
#63
Happy Birthday!!!
Few questions, Since 3genGS and 2genISx50 are using the same camber arms, the only company makes camber kit for IS is MeganRacing: http://www.meganracingperformance.co...sion-rods.html
Can we also use the toe control arm from IS? What is the rear adjustable upper arms? is that also call 'Upper camber arm"?
Meganracing makes rear adjustable traction arms for IS? does 3genGS have that arms too? what does it do?
#64
^ Thank you!
Yes they are all the same. You need the upper and lower camber arm (its the only two they make) They also have a Toe arm. So on the site you can find all 3, 2 are under one section, the other is under another section.
As for the specifics to what they each do I wouldnt be able to answer that. Maybe someone else can chime in on that.
#70
#73
Sorry guys....nothing until Saturday. My wife was in and out of the hospital so I havent touched the car. Was going to work on it last night but didnt have any time. The wait should be worth it?
#74
Worth the wait? Well, that's all on you. Depends what you show.
