★★★★★Passnu2 Build Thread★★★★★
#99
gotcha.. yeah i couldnt find anything for the 2is regarding the fronts and they look exactly like the ones for the is300s... hope to hear about this soon because i need to pull the trigger asap.. also lexus told me that is300 and our gs350 arms are not the same.. passnu mustve dug a lot deeper to figure this out..
#102
Yes the rears are for the ISx50, the front is meant for IS300. The fronts bolted up as I showed but I never tested them out and I havent taken my car for alignment. The rears are a direct match since the ISx50 and 3gen GS use the same parts. The front is not a direct match FYI...but it does bolt up.
Post how it goes since my car is still in pieces.
#104
Here is an update for everyone. I was able to get a Megan Racing Rear camber kit for our car. I purchased the same one that Passnu2 did. It was a Isx50 camber kit. I went ahead and installed it today but definately need a alignment now because the toe is off. Here are some pictures.
#105
I'm not quite sure that only having one of the two upper control arms adjustable will help. Obviously you can answer that. Were you able to successfully adjust (either negative or positive) the camber with just one of the two arms replaced? To me, the upper arm on the right should also be replaced to properly allow the knuckle to "tip" either in or out to adjust camber. But, maybe I'm wrong. Please let us know! It'll be great if we can get away with just one of the two. Thanks
