Build Threads Details on Club Lexus SC owner vehicles
My ´97 SC400
Old 04-04-11, 11:11 AM
  #136
pieisgude
pieisgude's Avatar
So you're going to use the Supra housing on the SC400?
Old 04-04-11, 03:02 PM
  #137
ScBouncE
ScBouncE's Avatar
very nice write up bro, gonna stayed tuned for this
Old 04-05-11, 10:27 AM
  #138
Boergy
Boergy's Avatar
HY!
yes, i will install the Supra housing in the SC
Yesterday evening, i rebuilt the both diffs. it was not difficult, all parts fits perfect
i tested also the clearance of the pinion and i was surprised, the both have also a clearance, but not so much as before the LSD in the SC housing, look in the vid.
i tested also only the pinion in th housings, the from the SC needs more energy for move as in the TT housing.
http://www.youtube.com/watch?v=SUkZH...layer_embedded
i hope, i become this friday the 35mm nut and then i can change the flange
greets
Boergsn
Old 04-05-11, 10:49 AM
  #139
stockhatch
stockhatch's Avatar
Whoa! That is a lot of free play. I would check backlash with a dial indicator for sure. That seems a bit extreme.
Old 04-05-11, 10:59 AM
  #140
Boergy
Boergy's Avatar
HY!
yes.. its much! but original! the SC diff have only 18600miles, and the TT Diff only 40000miles.
My friend will check his original diff with ~100.000miles and the Supra LSD with ~55.000miles. i hope he makes also a vid.
greets
Tom
Old 04-05-11, 02:24 PM
  #141
stockhatch
stockhatch's Avatar
You have me curious now. I am going to check mine too
Old 04-06-11, 01:34 PM
  #142
M3310
M3310's Avatar
I drive that many miles in a year!
Old 04-08-11, 11:09 AM
  #143
Boergy
Boergy's Avatar
HY!
Yesterday, i filled up the oil in the TT LSD and no clearance more feel and to hear ok..i s good
Today, i recieved the 35mm nut, but the was 5mm too short but we have "extended"
The flange to change is easy, but easer to do this on the car with closed rear brake to open the crew connection.
I fitted with the impact driver, first on stage 1 carfully and fixed complete with stage 4. Not more as 1-2mm more tighten up. its ok, not stronger to turn.
extended nut
flange SC vs Supra
pinion rearside
ready to install
greets
Tom
Old 04-09-11, 04:14 AM
  #144
Boergy
Boergy's Avatar
HY!
Today the final drive, all ok, no clearance, not more as original But the car feels lazy, all gears too long I tested with GPS 2 times 0-60miles. approx 7,8 seconds, not fast, With the oem diff was 7 sec. Next step this year or in the winter: change to 4.08 from the friends SC300 (is a open) with LSD
greets
Boergsn
Old 04-09-11, 12:11 PM
  #145
rmsc400
rmsc400's Avatar
Holy S*&T.
only 16k Miles?
Old 04-09-11, 02:13 PM
  #146
Boergy
Boergy's Avatar
Hello!
yes i think, today 168xx miles, not more
After a little turn with some tests and a refueled tank, the suspension are lower, and looks much better it feels not to hard, like oem sport
Supra TT diff installed
greets
Tom
Old 04-09-11, 07:08 PM
  #147
pieisgude
pieisgude's Avatar
You have such a nicely upgraded SC!
Old 05-14-11, 12:03 AM
  #148
Boergy
Boergy's Avatar
HY!
Last week, i go to my Lexus Dealer to adjust the suspension with the new setup, all ok! The SC drives very good
on the way home, i taked 2 pictures with my phone:
for a better light in the trunk, i changed the single LED to a led panel with warm white LED´s, it looks very good
in originla is a little bit more brighter.
Also, i bought 2 oem header gaskets, for the change to the new headers
fits perfect!
and to check the A/F, a AEM Gauge
Old 05-14-11, 12:11 AM
  #149
Boergy
Boergy's Avatar
One Problem with the new exhaust is, the tips going to outside of the car in the holes, and looks not good.
A friend had custom made this spacer for the rubber mountings.
before
after, looks better
on the other side the same
i hope, i can install on sunday the new centerpipe in the exhaust,
Old 05-14-11, 05:22 PM
  #150
TuanLegend
TuanLegend's Avatar
if u sold that car god damn thats probably 10k+
Quick Reply: My ´97 SC400
