My ´97 SC400
#257
Hello, yes, the are original Lexus Parts of 1997 not the most beautiful parts
yesterday i would install the LS400 calipers, all ok, shield perfect modified, not a big thing, but my wheels are have to less offset 6-7mm are missing to fit
i think to sell the parts.. or install 10mm spacers on each side, but looks this good? maybe.. i will nevertheless post the pictures from the install
#258
Hy!
ok.. start the install
remove old caliper
left SC right LS
screws
2 cuts with the cutting disc on the hub later....(little modfied)
disc test
don´t forget! little modification on the upper mount from the caliper
yeah!!!
and test on the evening
*****... not enough space for the calipers
greets
Tom
remove old caliper
left SC right LS
screws
disc test
yeah!!!
greets
Tom
#259
HY!
next update
The brake set is sold to a Soarer in Germany
The shock holder is welded and painted, installed with longer screws
longer screws
all parts
ready for weld
welded and painted
installed
today i started with the installation from the swap kit on my W58 tranny
next update
longer screws
all parts
ready for weld
welded and painted
installed
#260
here the pictures to the tranny, its a facelift W58 from a 97 Supra NA from Japan with steel center plate
beginn to remove the tripod to change the bearings
not the best part more
new summit racing bearings
upper tripod bushings..i will order new parts
this also new orderd
parts summary
inside picture
both adapter plates fitted
parts summary
inside picture
#261
T-56 bearing ready to modify
input change
output to the bleeder
****... the bearing will not fit
the hole is smaller as the pipe on the input shaft.... cut it!
adapter plate for the bearing fitted again
oh.... the screw have no place....
no problem... cut again
yeah! the bellhouse fits perfect
bellhouse inside
the last parts fitted on the clutch master cylinder
enough for the weekend next step is order the parts for the tripod.
greets
Tom
input change
bellhouse inside
greets
Tom
#262
hy, little update
all 4 fenders are rolled, but not perfect its ok, the tires have enough distance to the fender, no more contact more
[IMG]the tires have enough distance[/IMG]
i have become from a friend form his damaged tranny the speed sensor. the original from my w58 have no o-ring more and the contact pin is not original.. ok... new one installed, ready
good one
old defect one
ah! 32 tooth
new gasket
new bush and boot
summit racing bushings
good one
old defect one
ah! 32 tooth
new gasket
new bush and boot
#265
HY!
not much news, but today, my FETSPORTS strut brace is coming from Australia Is an used part for the supra, build in japan. fits to 98% perfect, only on the side with the intake pipe, must i the holder a little bit modify after this, paint the holder black and polish the strut
Pictures from the last fast phto shooting
#267
Hy!
Next part arrived
A GTSPEC rear strut brace very stiff, i tested it, i stand on it
Next week comes the Differential Pinion Mount Bushing SuperPro SPF2769KU frtom AUS
then i will swap back to the TT diff with the LSD, install the bushings, modify my shocks and install the strut bar after this is done, modify the front shocks ( i need a little higher for legal ) modify the strut bar to have no contact to the intake pipe and paint it
its winter yet in austria, but not too cold for do this things
greets
Tom
Next part arrived
greets
Tom
#268
Car is coming along nicely.
Its gotta be nice to have the tools and knowhow to make all those small adjustments to make mods work. A guy like me has to pay someone to do everything, although I'm debating whether or not I want to try the manual swap on my '99 myself..
