Build Threads Details on Club Lexus SC owner vehicles
Stockhatch's SC300 build thread
Old 10-12-10, 01:35 PM
  #76
stockhatch
stockhatch's Avatar
Well, I didn't need any special tools, so I guess you don't need any... 1/4 mile? I don't know, maybe never lol. Nah, I am sure I will track it one day, but no time soon since I have no LSD, am still on stock wussy tires, and the w58. Once I am LSD, on an R154 with some tires that will provide traction, maybe I will run it.
Old 10-12-10, 02:31 PM
  #77
soarer13oy
soarer13oy's Avatar
Nice, thanks for your help. I hope to see more of your build soon.
Old 10-12-10, 08:53 PM
  #78
BAD954BOI
BAD954BOI's Avatar
damn dude your a beast!!!! i cant wait to get my new leather after i go in on a quick clean up rebuild on my sc!!! CONGRATS DUDE!!
Old 10-13-10, 08:01 AM
  #79
lilSCsteve
lilSCsteve's Avatar
looking good bro, you move fast too!
Old 10-15-10, 10:32 AM
  #80
stockhatch
stockhatch's Avatar
Thanks guys! Valve seals this weekend I am not looking forward to this...
Old 10-25-10, 03:09 PM
  #81
stockhatch
stockhatch's Avatar
Man, now I know why I put off the valve stem seals this long. Anywho, they are done and will hopefully fix my cold start smoking issue.
Aside from the VSS, I finally fixed my cruise, and cranked the boost to around 14psi.
It seems to run fine at higher boost. Since it is a MBC, it spikes to 14psi and settles to around 13, but if I go any higher, it hits fuel cut, so that is it for now.
I didn't put the car on the dyno Friday as scheduled since my PS hose blew and I spent Friday having a replacement made and installing it.
My next step is to tweak my cruise with the clutch pedal switch, and fix my AC. I will post results on both.
Old 10-25-10, 06:05 PM
  #82
soarer13oy
soarer13oy's Avatar
Which cruise cable did you use?
Old 10-25-10, 06:11 PM
  #83
stockhatch
stockhatch's Avatar
I made one. It was a total PITA. Believe it or not, the cruise cable is smaller diameter cable than the throttle cable, and was a prefect match to bicycle brake cable.
I made barrel ends out of brass rod stock, drilled, notched, and sweated the ends on. It works great.
Old 10-25-10, 06:20 PM
  #84
soarer13oy
soarer13oy's Avatar
So i guess i should just buy a supra lol. Were you able to find some usdm turbos?
Old 10-25-10, 06:43 PM
  #85
stockhatch
stockhatch's Avatar
I think so, but I am waiting on dude to email me some pics. You are going to try a Supra cruise cable? Let me know if it works. It almost looks a bit short to me so I am curious. That's why I just decided to make one for $15 instead of risking the Supra one not fitting.
Old 10-25-10, 06:48 PM
  #86
soarer13oy
soarer13oy's Avatar
Yeah im going to try the cruise cable. I hope its not too short cause that would be a waste of $. I kinda figured it would be able to fit since its a gte also.
Old 04-10-11, 01:57 PM
  #87
stockhatch
stockhatch's Avatar
Doing a bottom end refresh for various reasons, here are the pics of the rod bearings. Is this normal wear and tear? It looks like a couple journals have some taper judging by the wear pattern...The bearings on the piston side look like this, and the bottom side is uniform and show very little wear. I had cold startup rattle too, so maybe the worn bearings were the culprit.
Mains looked really good IMO. There was one main that had some scoring from debris, but otherwise, the crank and bearings looked better than I expected.
Old 04-10-11, 02:21 PM
  #88
6SOARER
6SOARER's Avatar
Damn, you move quick man.
You planning on re-using the bearings or replacing em with new ones?
Old 04-10-11, 03:01 PM
  #89
stockhatch
stockhatch's Avatar
Thanks man. I am going to do all new bearing even though a couple of them still look new. New bearings, new rod bolts, new main bolts, arp head studs etc.
Old 04-10-11, 03:13 PM
  #90
WetLexus
WetLexus's Avatar
^^^ You are a beast man. Set-up looks beautiful inside and out! Good luck with ur refresher!!
Quick Reply: Stockhatch's SC300 build thread
