ProjectGS#2: NA-T Build in 24 hours.
#47
For those of you wondering, yes I'm working on developing a turbo kit for this car. I still need to do some more testing and research, so I have not announced anything official yet. I'm waiting on a few things in line to be completed and I will become a vendor here on CL. Most of the things I'll be offering are hard to find items that you probably won't find anywhere or stuff that just doesn't exist for this car. My goal is to make a bolt on kit with all electronics + pre-tuned for the GS300 that will not set off any check engine lights and will still pass plug in OBD2 testing.
I'll need a few extra guinea pigs in the future
#49
I'll need a few extra guinea pigs in the future![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Make it as complete as possible for those noobs, like me. It'd nice to have a true bolt-on kit.
#50
#52
You should finish your timing belt videos if you pull the head.
#59
I'm sure a inspector is more willing to let visual slide if the car has no check engine lights.
I'm working on some way to hide everything to make it look very OEM including use of the stock air box and snorkel. Piping will be powdercoated wrinkle black finish to look OEM and the intercooler coated in black as well. Thinking about including a catalytic converter in the exhaust piping as well. Then the car should pass both the sniffer and plug in obd2 test, just not the visual if the inspector knows what's going on
#60
Awesome work!
I highly recommend using an oil feed restrictor on your turbos to drastically prolong the life of the turbo and a SS braided return line. Anything else would melt or eventually crack since its under constant high heat. You might need an extra fitting depending on how you flex the SS hose.
