Build Threads Details on Club Lexus 2GS owner vehicles
ProjectGS#2: NA-T Build in 24 hours.
Old 07-29-10, 11:09 AM
  #61
MobbinVIP
MobbinVIP's Avatar
Originally Posted by JeffTsai
For those of you wondering, yes I'm working on developing a turbo kit for this car. I still need to do some more testing and research, so I have not announced anything official yet. I'm waiting on a few things in line to be completed and I will become a vendor here on CL. Most of the things I'll be offering are hard to find items that you probably won't find anywhere or stuff that just doesn't exist for this car. My goal is to make a bolt on kit with all electronics + pre-tuned for the GS300 that will not set off any check engine lights and will still pass plug in OBD2 testing.
I'll need a few extra guinea pigs in the future
Can't wait!
I'm down to be a guinea pig
  #62
JeffTsai
JeffTsai's Avatar
Originally Posted by K3RRY
Awesome work!
I highly recommend using an oil feed restrictor on your turbos to drastically prolong the life of the turbo and a SS braided return line. Anything else would melt or eventually crack since its under constant high heat. You might need an extra fitting depending on how you flex the SS hose.
The oil feed flange on top of the turbo is a Function7 AN-4 oil feed flange made of billet 7075 aluminum with a built in oil restrictor. The drain line is just temporary right now, I just needed something rigged up so I can start the engine without spilling oil everywhere. It has since been replaced with a reinforced silicone hose. Just in case you didn't know, those SS braided hoses aren't invincible. They are just a standard reinforced rubber hose inside with a stainless steel braid on the outside. The rubber inside can melt and crack around 300F or so. The silicone hose I use is rated for 550F continuous heat!
If you check my first post in this thread, the blue hose in that picture on the drain line is what I use. Purosil multi layer reinforced silicone hose. Trust me, I have had enough trial and error in doing this stuff and I have all my bases covered
Thanks for asking though, most people don't even notice stuff like that.
Old 07-29-10, 11:41 AM
  #63
speedaddic
speedaddic's Avatar
We don't have Visuals here in TX. I remember those when I lived in CA...lol...all my cars are boosted or engine swapped (k20 ek)... + for living in TX.
Old 07-29-10, 11:48 AM
  #64
Frankdorn
Frankdorn's Avatar
Its crazy how easy you make that look. I know its early, but any horsepower estimates for the kit you'd put together? Do you know if any pieces of the kit would fit the IS or SC?
Old 07-29-10, 12:01 PM
  #65
arpham
arpham's Avatar
Numbers please! I also need to start saving up for a jefftsai kit.
Old 07-29-10, 12:14 PM
  #66
Anthony
Anthony's Avatar
^same, saving up!
Old 07-29-10, 07:34 PM
  #67
kamlung
kamlung's Avatar
ill be willing to guinea pig my 430 if u want...
Old 07-29-10, 08:24 PM
  #68
ThomasGS4
ThomasGS4's Avatar
I'll be a guinea pig if you need a 400. Lol
Old 07-29-10, 08:47 PM
  #69
LEXUS_KID
LEXUS_KID's Avatar
Old 07-30-10, 10:26 AM
  #70
LexFather
Guest
Posts: n/a
JEff ftw!!! Thanks for your continued leadership with the 2GS!
Old 08-01-10, 01:47 AM
  #71
pingu
pingu's Avatar
Yeah, I said it will pass plug in OBD2
I'm sure a inspector is more willing to let visual slide if the car has no check engine lights.
I'm working on some way to hide everything to make it look very OEM including use of the stock air box and snorkel. Piping will be powdercoated wrinkle black finish to look OEM and the intercooler coated in black as well. Thinking about including a catalytic converter in the exhaust piping as well. Then the car should pass both the sniffer and plug in obd2 test, just not the visual if the inspector knows what's going on
The smog check process is a big deal for most test only centers in CA (that's what happens when voters enact strict environmental laws ). You would probably need to include a cat on the down pipe for people in strict states. I never did replace my B-pipe with the Megan one, so I don't know if my 300 would pass with only 2 cats.
I could only wish I lived in a free state.
Old 08-01-10, 01:52 AM
  #72
RAWKUSsd
RAWKUSsd's Avatar
nice set up
Old 08-01-10, 04:33 AM
  #73
VNN326
VNN326's Avatar
nice jeff, always entertaining watching your builds. NEXT UP VIDEO OF THE START UP!!?
Old 08-01-10, 05:54 AM
  #74
YviE
YviE's Avatar
A metallic cat would be ideal because of less restriction.
I am pretty sure my GS300 only has 2 cats, those is on the headers. My downpipe has a resonator, but no cat (I have seen downpipes with cat though).
It passes smog just fine.
Old 08-01-10, 06:33 AM
  #75
JeffTsai
JeffTsai's Avatar
Sorry, was busy and did not remember to update this post lol. I've had the car running for 2 days now and driving around. I'll be posting updated pictures and some videos soon
Quick Reply: ProjectGS#2: NA-T Build in 24 hours.
