SC400TT Project Car Stage II
#1369
Communication
Hello Ryan.
I'm glad that you continue your project.
But given the weather forecast, you should put the car in a safe place to keep it without damage, remove the battery and take care of yourself and your family
Sincerely, Vadim.
Sincerely, Vadim.
#1372
More updates
Now fixing the tune and the fueling...Fixed the slight overheating problem. Just moved the whole radio support forward. More space now between the fans and the DP. Really worked out! Plus, got rid of the metal corrugated hot rod water tubing and added black braided hose and -20 AN’s. Now the routing is proper too!
Added black CF, more CF coming...inside and out.
Rebuilt the steering wheel out of carbon and flattened the bottom. Added thumb grips too. Redid the stick shift **** to match.
More to come.
More to come.
aswang (12-13-17)
#1374
Did you weld the AN bungs on to the radiator? It looks like you used the hose to AN adapter on the block side. If you dont mind, what sizes did you use? Thanks!
#1375
Just wanted to share this video Jay made for Ryan's SC400TT. Some of y'all may have seen it on FB, as Ryan is more active on there now. Enjoy!
Jay himself have a 1JZ swapped drift 240SX btw!
