Build Threads Details on Club Lexus SC owner vehicles
project:Soarer
Old 09-14-11, 07:08 PM
  #61
99SC42
99SC42's Avatar
Cooler is for the Power steering under the driver side headlamp.
Yes just get the TT water pump from toyota and bolt straight swap, it's a little PITA with the twins on there if you are replacing the whole assy but it can be done.
Don't forget the flange for the oil return line.
Old 09-15-11, 08:07 PM
  #62
biturbo632
biturbo632's Avatar
Nice work!! You'll love the 1JZ! I can't complain about it!
Old 09-20-11, 10:14 PM
  #63
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
any update?
Old 09-20-11, 10:23 PM
  #64
1J0Z SC
1J0Z SC's Avatar
I would like to see updates as well, where did you get the clutch master cylinder for $42 shipped?!?! Thats crazy cheap and I need a new one
Old 09-20-11, 10:53 PM
  #65
unknown159
unknown159's Avatar
great write up cant wait to see it finished
Old 09-21-11, 05:30 AM
  #66
megamax
megamax's Avatar
I actually picked that up on ebay. And as far as updates? Ordered and got a set of mk4 supra obx silicone radiator hoses. And going to get a clutch slave from autozone for 30 beans. Priced out my final tally to get the car running(including 350 for registration and 200 for a new windshield) and it's going to be 3k. Unless I can find a clutch pedal set chepear than 360? Planning on having this done before the end od the year. I want tx2k12.
Old 10-08-11, 05:42 PM
  #67
megamax
megamax's Avatar
so i finally got some time to get the oil pan switched out to the rear sump from my 2jzge. it was a fairly direct and easy swap as ive taken one of these off before. there is still a ****load of bolts..
i used the bolts directly off the 1jz front sump. and i needed 5 more from the ge stash.
the crankcase itself looks really good. not that much grime on it actually. big difference between this and my 230k ge bottom end.
and the rear sump assembly going on.
without a hitch.... except i broke off one bolt in the back when installing the pan-pan. it is in the alum assembly. so the rest of the bolts didn't torque them so hard.
couldn't find tq specs or bolt tighting sequences, so i had to use wing it and do a crisscross pattern like with my rb..
go rear sump POWER!! so i hear i need a mk4 supra oil return tube. but i might just try to find/fabb some rubber hoses to make the 1jz tube work..
the day after i did this the toyota fipg still didn't cure. iam not going to have this running anytime soon, but still weird that after 24hrs it's still not hard(need cialis).
so i got these 2jzge engine mounts. and i don't know which one is for right or left?? any help
and i went to the junkyard and scored a 94 camry 4 cylinder throttle cable. i hear i need a 95. But hopefully this will suffice. testimating the throttle length this will work..
that is all.. sorry this is moving slower than aids. but it's been a rough year. hoping to get this done for txtk12 before 12/12/12 yikes!!!
Old 10-08-11, 06:32 PM
  #68
brerrabbit
brerrabbit's Avatar
Well, good luck and godspeed. This has given me hope and not just a little heartburn, because at some point I want to start tearing my car apart (will have to be once I have another daily).
Can I propose the name of Frankenstein for it? Somehow seems appropriate, especially if you've ever found yourself laughing hysterically or being chased by angry villagers.
Great build, and thanks for inspiring.
Old 10-08-11, 07:03 PM
  #69
account2x
account2x's Avatar
IN should be intake
EX should be exhaust
camry cable can be made to work but the fitment is awful.
Old 10-08-11, 07:40 PM
  #70
99SC42
99SC42's Avatar
IIntake side will say IN and exhaust will say EX.
Gl with the swap .
Old 10-09-11, 08:45 PM
  #71
megamax
megamax's Avatar
Originally Posted by account2x
IN should be intake
more on this cable thing please??
Old 10-13-11, 06:22 PM
  #72
megamax
megamax's Avatar
so i installed the sc300 engine mounts.. had to remove the oil tree but no biggie. and i mounted the sc300 oil dipstick. and i mounted the w58 slave.
also mounted the ac condensor, so iam almost ready to rock..
-water pump assembly.
-need flywheel
-cltuch kit,with flywhl bolts.
-engine harness and enging mounts..
then i can stick this sucker in the car..
now i can use any mk4 supra engine mounts for this correct??
and also does anyone have a part number for the mk4 supra oil return neck?? and an approx price??
Old 10-13-11, 07:42 PM
  #73
account2x
account2x's Avatar
Use 97-98 Supra Engine Mounts 12360-46111
Camry cable is far too long but ironically the actual wire rope length is too short and the amount of threading at the end is almost non existent giving no slack control. Overall the fitement is crap.
Old 10-13-11, 09:28 PM
  #74
megamax
megamax's Avatar
thank you account. always helpful. but i needed the p/n for the lower oil return neck off a mk4 supra??
Old 11-01-11, 12:12 PM
  #75
megamax
megamax's Avatar
well finally got a hold of a w58 from a sc300. had to go the fires of mt.doom to get it though...
wanna give a shoutout to cl member. 96SC
Quick Reply: project:Soarer
