project:Soarer
#123
so, got another shirt to show my jdm madness for the toyota life..
![](http://i495.photobucket.com/albums/rr317/supersayianjim/lex%20file/reppingthe1j.jpg)
and onto hard parts stuff!!! finally got my e-fay high beams in. mocked them up to my "naked" front of my sc/
![](http://i495.photobucket.com/albums/rr317/supersayianjim/lex%20file/eglightmockup.jpg)
![](http://i495.photobucket.com/albums/rr317/supersayianjim/lex%20file/egmockup2.jpg)
and i started my process of painting the housing on my headlights black. i find it easier to do x2 different minutes of 6 at 300 degrees. i used a flat tip screwdriver to peel them apart..
![](http://i495.photobucket.com/albums/rr317/supersayianjim/lex%20file/intheoventheygo.jpg)
got them, both apart. and will show more pics of this when i start painting them in "gloss" black!!
#124
okay so now i cleaned up the headlight housing and gave it a spray..
![](http://i495.photobucket.com/albums/rr317/supersayianjim/lex%20file/paintedheadlight.jpg)
after 2 coats doused it with some acrilic enamel.
so heres my question cl people. to the folks that have done this mod. do i spray this black also??? or do i leave it as it is?? will spraying it reduce visibility??
![](http://i495.photobucket.com/albums/rr317/supersayianjim/lex%20file/headlightreflec.jpg)
#125
1JZ Single SC400
Thats a good question. I think if you spray them, it will interfere with the lighting. I dont know for sure, just assuming. I left mine bone stock and cleaned them up and resealed them silicone.
Nice build by the way.. Are you following mine or what??? :-)
#127
man i was definitely in your position, i just got new headlights, highs and fogs(cornering lights) and under went the task yesterday after trying to do my brakes to find out i got shipped rotors that where to big
but yea i expected a ~2hrs to remove bumper install lights and reinstall bumper...2hrs later i finally got the bumper off, so many bolts and clips!!
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#129
so what happend was............
was browsing craigs list, why because i always do looking for a break... and i found one..
![](http://i495.photobucket.com/albums/rr317/supersayianjim/lex%20file/2CALH8JXF.jpg)
![](http://i495.photobucket.com/albums/rr317/supersayianjim/lex%20file/SANY0007.jpg)
![](http://i495.photobucket.com/albums/rr317/supersayianjim/lex%20file/SANY0004.jpg)
![](http://i495.photobucket.com/albums/rr317/supersayianjim/lex%20file/SANY0003.jpg)
reporetly off a 92 cummings. snagged this hx h1c(an old hx35) for a cool 100 bones.
0 i mean 0 shaft play. dosen't appear to had been leaking oil and looks overall like a solid turbo.
bigger than in the pics hard to imagine a simple 40 bigger than this. hoping to slap this on my 1jz and make some real hp.
but for the time being, iam pretty sure this is going to max out the stock injectors..
