Build Threads Details on Club Lexus 2GS owner vehicles
2Gen GS300...LS2 6-Speed Build Thread
Old 01-18-12, 06:33 PM
  #226
battery188
battery188's Avatar
Mike,
just dropping by to say hello.
Everything looks good! especially the tranny cover w/ cup holders. so they clear all 6 gears and reverse? I went different route but that deffinately looks clean!
Peter
Old 01-18-12, 06:53 PM
  #227
99 GS3
99 GS3's Avatar
Originally Posted by AMSMIKE
re-doing the center console to make the factory one work WITH cup holders!
next up (this weekend) make the shift boot!
Peter
Agreed nicely done. That trans must have the tightest pattern ever to have full swing with only that much width. Toyota transmissions have the 5 gear way out in right field, I tried to get it all inside the hole, even if I had cut/angled the shifter it still wouldn't work. I used a C's short throw shifter which brought the pattern in considerabley but 5th is still a mile away from third..
Old 01-19-12, 12:15 AM
  #228
AMSMIKE
AMSMIKE's Avatar
Mike,
Peter
Hi peter. Only when getting into reverse does the shifter rod barely touch the bottom of the cup holders. Not enough to bother me. All 1-6 gears clear with about 3/4" on left and right side.
Hope you're car is coming along
thank you!
Yes the T-56 has a very close 1st through 6th and not wide spread out like the toyota or a honda.
Old 01-19-12, 12:18 AM
  #229
AMSMIKE
AMSMIKE's Avatar
here is 6th gear to give you an idea....
Old 01-19-12, 07:03 AM
  #230
AKS14
AKS14's Avatar
So does it get in to reverse?
Old 01-19-12, 11:13 AM
  #231
AMSMIKE
AMSMIKE's Avatar
i don't use reverse. I just roll the car back with my feet. 5 point turns and parallel parking gives my feet a work out
Old 01-20-12, 09:14 PM
  #232
gs300yerg
gs300yerg's Avatar
Like a BOSS
Old 01-20-12, 10:33 PM
  #233
AMSMIKE
AMSMIKE's Avatar
Originally Posted by gs300yerg
Like a BOSS
Old 01-21-12, 07:26 PM
  #234
00Formula
00Formula's Avatar
Originally Posted by 00Formula
Did you ever measure your pan to see if this one would clear the cross member? Visually the lower sump division is between two bolt holes in the pan, which looks very close to the ones I've seen modified on here. I can weld steel, I just don't have the resources to weld thick aluminum like that easily.
Old 01-21-12, 09:58 PM
  #235
AMSMIKE
AMSMIKE's Avatar
haven't even pulled her out of the garage. been super busy.
I will try this week
Old 01-22-12, 09:50 AM
  #236
00Formula
00Formula's Avatar
I understand, I worked every day this week and did nothing on the project car.
Old 01-26-12, 04:50 PM
  #237
AMSMIKE
AMSMIKE's Avatar
totally forgot to measure. i will have it on the lift next week and i wrote myself a note.
Old 01-26-12, 04:55 PM
  #238
AMSMIKE
AMSMIKE's Avatar
New wheels are on and the car looks much better. These wheels flow better and i like the fitment and fat tires.
Work Emotion 11R
18x8.5 +38
255/40 tires
18x9.5 +38
285/35 tires
cell phone pictures for now...
Old 01-26-12, 05:03 PM
  #239
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Car looks great Mike...
Old 01-26-12, 05:06 PM
  #240
AMSMIKE
AMSMIKE's Avatar
Thanks!
i feel like the front should be just a tad lower, I'll wait until everything settles then adjust.
Quick Reply: 2Gen GS300...LS2 6-Speed Build Thread
