SC570--The OFFICIAL build thread
#409
When I get my cross members made I'll send you a pic and we might be able to work something out to help with clearance
#410
#413
Jimmy, I will let you know. I meant to give you a call today and just..
#415
Things just got serious Chris!!
If i were you i will just pick up an ecu that does ff and dump so e85 in there , ill will make your setup very reliable and not have to worry about detonation.
Get that lq4 and make 900wtq lol , easy on these engine that's why it's my favorite V8 engine..
Im thinking about doing the lq9 or the LY6 with S376- 80mm!!
What clutch are you running? These twin discs are cheaper than any twins disc i have ever seen.
How much are you in this setup so far? give or take.
#419
As for the LQ4, that will come along when the aluminum 5.7 gives up. Clutches, Ive been looking at a few, but leaning towards the McLeod RXT with SFI flywheel. Rated to 1000hp, and should still be easy on the left leg and its under $1500.
Into the turbo portion, not too much actually. Got the S475 on a labor day sale that knocked off another $150 (
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
I can only imagine at this point. Its a blast as it is now being n/a, but looking forward to boosting again.
Thanks. And all it takes is a bit of time and dirty/bloody hands to get that mechanical touch.
#420
Chris my Tuner is Big GM and DSM guy, He has been begging me to get the LY6 and let him do his magic on it.
S376 is the same as the your S475! different people call it different names.
They are all t4 frames Turbos, not T6.
You right i have seen couple S366 Twin setups , but I really don't like Twin setups.
I got couple pricing on this stuff and it actually cheaper than build than the JZs stuff..
LY6 motor , Harness , ecu $2500
Tr6060 brand new $3000
Motor mount $800
Clutch MC leod twin $1600
Injectors $1000
DS $500
Cross pipe for Turbo $800
LS9 HG $90
Misc $1000
Cam Comp $350
flex Fuel Sensor kit $110
Weldon FP regulator $200.
I have been tinking about the idea for a longtime so i may just pull the trigger![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
I can't wait till you install that turbo!
Motor mount $800
Injectors $1000
DS $500
LS9 HG $90
Misc $1000
Cam Comp $350
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
