Either Finished Or Work-In-Progress *Show Off Your Build*
I thought it would be nice to see what everyone is currently working on, or in case I missed your build thread in the ocean of "need help" threads, post up a few pics of your badass SC. And try not to make this become another random pic thread. This thread is for pics and descriptions of MODIFIED SC'S ONLY
Here's some teaser pics of what Im working on.
I bought these tail lights to use the clear lenses on my oem tails but they dont fit, so im stuck with these for now. I kinda like em though.
Cold Air Intake.
1: I purchased a 3" Aluminium 1998-2000 LEXUS GS300 SHORT RAM AIR INTAKE W/FILTER.
2: Cut out a section of pipe with the MAF Housing
3: Used Two 90 Degree & One 45 Degree 3" Aluminium Mandrel Bent Pipes
4: Installed all Pipes with Duck Tape for Test Fit
5: I placed a 1.25" tubing to Recirculate the BOV discharge after the MAF sensor
6: Take Pipes off to be Welded
7: After Welding was completed. I Test fitted the New Air Intake Pipe
8: Took the Pipe off to be Powder Coated Purple.
![Name: Picture590.jpg
Size: 104.2 KB](https://www.clublexus.com/forums/attachments/build-threads/460718d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture590.jpg)
![Name: Picture591.jpg
Size: 100.1 KB](https://www.clublexus.com/forums/attachments/build-threads/460719d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture591.jpg)
![Name: Picture606.jpg
Size: 56.5 KB](https://www.clublexus.com/forums/attachments/build-threads/460721d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture606.jpg)
Part II.
Cold Side Intercooler Pipe.
1: 3" 90 Degree Aluminium Mandrel Bent Pipe
2: 2.5" 90 Degree Aluminium Mandrel Bent Pipe
3: 2.5" - 3" Aluminum Reducer
5: Take Pipes off to be Welded
6: After Welding was completed. I Test fitted the New Cold Side Intercooler Pipe
7: Took the Pipe off to be Powder Coated Purple.
![Name: Picture604-1.jpg
Size: 119.5 KB](https://www.clublexus.com/forums/attachments/build-threads/460722d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture604-1.jpg)
2.5" - 3" Aluminum Reducer.
![Name: Picture588.jpg
Size: 120.3 KB](https://www.clublexus.com/forums/attachments/build-threads/460723d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture588.jpg)
Special Thanks to Macgyver for all the Welding.
I still need to add the AEM Air Bypass Valve
A Few Installation Photos.
![Name: Picture600.jpg
Size: 156.9 KB](https://www.clublexus.com/forums/attachments/build-threads/460724d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture600.jpg)
![Name: Picture601.jpg
Size: 167.5 KB](https://www.clublexus.com/forums/attachments/build-threads/460725d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture601.jpg)
![Name: Picture594.jpg
Size: 105.0 KB](https://www.clublexus.com/forums/attachments/build-threads/460726d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture594.jpg)
![Name: Picture599.jpg
Size: 82.3 KB](https://www.clublexus.com/forums/attachments/build-threads/460727d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture599.jpg)
![Name: Picture597.jpg
Size: 126.0 KB](https://www.clublexus.com/forums/attachments/build-threads/460728d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture597.jpg)
![Name: Picture602.jpg
Size: 169.4 KB](https://www.clublexus.com/forums/attachments/build-threads/460729d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture602.jpg)
![Name: Picture607.jpg
Size: 175.8 KB](https://www.clublexus.com/forums/attachments/build-threads/460730d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture607.jpg)
Part II.
![Name: Picture609.jpg
Size: 167.8 KB](https://www.clublexus.com/forums/attachments/build-threads/460731d1501791993-either-finished-or-work-in-progress-show-off-your-build-picture609.jpg)
Black cherry kandy over copper metallic.took out all the dints and fenders/quarters were banged up a little after rolling them, so fixed that too.Shaved all the emblems and the 3rd brake light in the rear spoiler.
![Name: bprimer-1.jpg
Size: 60.4 KB](https://www.clublexus.com/forums/attachments/build-threads/460732d1501791993-either-finished-or-work-in-progress-show-off-your-build-bprimer-1.jpg)
![Name: primed.jpg
Size: 62.0 KB](https://www.clublexus.com/forums/attachments/build-threads/460733d1501791993-either-finished-or-work-in-progress-show-off-your-build-primed.jpg)
![Name: copper.jpg
Size: 59.1 KB](https://www.clublexus.com/forums/attachments/build-threads/460734d1501791993-either-finished-or-work-in-progress-show-off-your-build-copper.jpg)
![Name: cherry.jpg
Size: 68.6 KB](https://www.clublexus.com/forums/attachments/build-threads/460735d1501791993-either-finished-or-work-in-progress-show-off-your-build-cherry.jpg)
![Name: base.jpg
Size: 78.3 KB](https://www.clublexus.com/forums/attachments/build-threads/460736d1501791993-either-finished-or-work-in-progress-show-off-your-build-base.jpg)
car isnt fully put toghether yet
1.daizen front control arm bushings already done
2.Valve seals,timingbelt,w/p, seals, distrubitor oring, plugs,wires, v/c gaskets done
3.Fixed the Climate screen with an ebay unit
4.sold TT wheels and bought lm replica 19s
5.got 3 spoke wheel from aligia
6.Picked up a Oem sc4 front lip
things still left to do before spring
1.get coil overs
2.send the climate,cluster and radio to OLT to get it all done in pure white
3. put the car toghether
![Name: primed.jpg
![Name: copper.jpg
![Name: cherry.jpg
![Name: base.jpg
1.get coil overs
When i first bought the SC
![Name: PB280113.jpg
Size: 114.5 KB](https://www.clublexus.com/forums/attachments/build-threads/460737d1501791993-either-finished-or-work-in-progress-show-off-your-build-pb280113.jpg)
![Name: Drifting.jpg
Size: 18.4 KB](https://www.clublexus.com/forums/attachments/build-threads/460738d1501791993-either-finished-or-work-in-progress-show-off-your-build-drifting.jpg)
next, Offset white, with a slight olive clear and 97+ front with tien basics
![Name: DSCF2045.jpg
Size: 62.2 KB](https://www.clublexus.com/forums/attachments/build-threads/460739d1501791993-either-finished-or-work-in-progress-show-off-your-build-dscf2045.jpg)
Then came the Black work equips
![Name: 100_1679.jpg
Size: 64.1 KB](https://www.clublexus.com/forums/attachments/build-threads/460740d1501791993-either-finished-or-work-in-progress-show-off-your-build-100_1679.jpg)
![Name: 103_1600.jpg
Size: 108.1 KB](https://www.clublexus.com/forums/attachments/build-threads/460741d1501791993-either-finished-or-work-in-progress-show-off-your-build-103_1600.jpg)
![Name: 3054675170_f35d9bbf65_b.jpg
Size: 93.9 KB](https://www.clublexus.com/forums/attachments/build-threads/460742d1501791993-either-finished-or-work-in-progress-show-off-your-build-3054675170_f35d9bbf65_b.jpg)
![Name: 3376757767_b50b8aa1f0_b.jpg
Size: 40.6 KB](https://www.clublexus.com/forums/attachments/build-threads/460743d1501791993-either-finished-or-work-in-progress-show-off-your-build-3376757767_b50b8aa1f0_b.jpg)
Going for paint, Added 97+ side skirts and roof wing. Blacked out my head light houseings, and added Purple LEDS to my high beams.
![Name: DSCF2565.jpg
Size: 103.4 KB](https://www.clublexus.com/forums/attachments/build-threads/460744d1501791993-either-finished-or-work-in-progress-show-off-your-build-dscf2565.jpg)
![Name: DSCF2594.jpg
Size: 66.4 KB](https://www.clublexus.com/forums/attachments/build-threads/460745d1501791993-either-finished-or-work-in-progress-show-off-your-build-dscf2594.jpg)
![Name: 3715282862_2c9237894f_b.jpg
Size: 150.5 KB](https://www.clublexus.com/forums/attachments/build-threads/460746d1501791993-either-finished-or-work-in-progress-show-off-your-build-3715282862_2c9237894f_b.jpg)
![Name: 3715281666_9563cf9810_b.jpg
Size: 57.8 KB](https://www.clublexus.com/forums/attachments/build-threads/460747d1501791993-either-finished-or-work-in-progress-show-off-your-build-3715281666_9563cf9810_b.jpg)
New wheels, Another set of equips
![Name: IMG_0170.jpg
Size: 80.4 KB](https://www.clublexus.com/forums/attachments/build-threads/460748d1501791993-either-finished-or-work-in-progress-show-off-your-build-img_0170.jpg)
![Name: IMG_0141.jpg
Size: 67.5 KB](https://www.clublexus.com/forums/attachments/build-threads/460749d1501791993-either-finished-or-work-in-progress-show-off-your-build-img_0141.jpg)
![Name: IMG_0186.jpg
Size: 88.6 KB](https://www.clublexus.com/forums/attachments/build-threads/460750d1501791993-either-finished-or-work-in-progress-show-off-your-build-img_0186.jpg)
Wide body! molded 97 rear extentions, and 97 rear bumper
![Name: 24732_414559807577_507067577_532826.jpg
Size: 51.2 KB](https://www.clublexus.com/forums/attachments/build-threads/460751d1501791993-either-finished-or-work-in-progress-show-off-your-build-24732_414559807577_507067577_532826.jpg)
![Name: IMG_0235.jpg
Size: 46.0 KB](https://www.clublexus.com/forums/attachments/build-threads/460752d1501791993-either-finished-or-work-in-progress-show-off-your-build-img_0235.jpg)
![Name: IMG_0283.jpg
Size: 28.6 KB](https://www.clublexus.com/forums/attachments/build-threads/460753d1501791993-either-finished-or-work-in-progress-show-off-your-build-img_0283.jpg)
![Name: IMG_0302.jpg
Size: 20.7 KB](https://www.clublexus.com/forums/attachments/build-threads/460754d1501791993-either-finished-or-work-in-progress-show-off-your-build-img_0302.jpg)
![Name: IMG_0277.jpg
Size: 27.2 KB](https://www.clublexus.com/forums/attachments/build-threads/460755d1501791993-either-finished-or-work-in-progress-show-off-your-build-img_0277.jpg)
![Name: IMG_0305.jpg
Size: 6.4 KB](https://www.clublexus.com/forums/attachments/build-threads/460756d1501791993-either-finished-or-work-in-progress-show-off-your-build-img_0305.jpg)
![Name: Image.jpg
Size: 82.3 KB](https://www.clublexus.com/forums/attachments/build-threads/460757d1501791993-either-finished-or-work-in-progress-show-off-your-build-image.jpg)
![Name: 100_3234.jpg
Size: 109.3 KB](https://www.clublexus.com/forums/attachments/build-threads/460758d1501791993-either-finished-or-work-in-progress-show-off-your-build-100_3234.jpg)
![Name: 100_3236.jpg
Size: 130.5 KB](https://www.clublexus.com/forums/attachments/build-threads/460759d1501791993-either-finished-or-work-in-progress-show-off-your-build-100_3236.jpg)
![Name: Image.jpg
![Name: rolloutf.jpg
Size: 88.1 KB](https://www.clublexus.com/forums/attachments/build-threads/460760d1501791993-either-finished-or-work-in-progress-show-off-your-build-rolloutf.jpg)
![Name: fontana2011002.jpg
Size: 98.8 KB](https://www.clublexus.com/forums/attachments/build-threads/460785d1501791993-either-finished-or-work-in-progress-show-off-your-build-fontana2011002.jpg)
The joy of leaking valve covers
![Name: fontana2011005.jpg
Size: 91.3 KB](https://www.clublexus.com/forums/attachments/build-threads/460786d1501791993-either-finished-or-work-in-progress-show-off-your-build-fontana2011005.jpg)
![Name: fontana2011008.jpg
Size: 58.9 KB](https://www.clublexus.com/forums/attachments/build-threads/460787d1501791993-either-finished-or-work-in-progress-show-off-your-build-fontana2011008.jpg)
Ripping on "sport cars"
![Name: fontana2011010.jpg
Size: 84.4 KB](https://www.clublexus.com/forums/attachments/build-threads/460788d1501791993-either-finished-or-work-in-progress-show-off-your-build-fontana2011010.jpg)
![Name: fontana2011027-1.jpg
Size: 53.4 KB](https://www.clublexus.com/forums/attachments/build-threads/460789d1501791993-either-finished-or-work-in-progress-show-off-your-build-fontana2011027-1.jpg)
![Name: fontana2011040.jpg
Size: 80.5 KB](https://www.clublexus.com/forums/attachments/build-threads/460790d1501791993-either-finished-or-work-in-progress-show-off-your-build-fontana2011040.jpg)
Almost 3 years ago
![Name: DSC00357.jpg
Size: 113.6 KB](https://www.clublexus.com/forums/attachments/build-threads/460791d1501791993-either-finished-or-work-in-progress-show-off-your-build-dsc00357.jpg)
![Name: DSC00389.jpg
Size: 85.2 KB](https://www.clublexus.com/forums/attachments/build-threads/460792d1501791993-either-finished-or-work-in-progress-show-off-your-build-dsc00389.jpg)
![Name: DSC00400.jpg
Size: 95.8 KB](https://www.clublexus.com/forums/attachments/build-threads/460793d1501791993-either-finished-or-work-in-progress-show-off-your-build-dsc00400.jpg)
As it sits now
![Name: 162610_500641322157_833372157_6005461_482003_n.jpg
Size: 73.0 KB](https://www.clublexus.com/forums/attachments/build-threads/460795d1501791993-either-finished-or-work-in-progress-show-off-your-build-162610_500641322157_833372157_6005461_482003_n.jpg)
The stig-meister
![Name: 167724_500642202157_833372157_6005496_6661184_n.jpg
Size: 53.7 KB](https://www.clublexus.com/forums/attachments/build-threads/460796d1501791993-either-finished-or-work-in-progress-show-off-your-build-167724_500642202157_833372157_6005496_6661184_n.jpg)
She's been my project for the last 3 years.
If you can say about your project "it's done", you either have no objective or don't have a project at all. Car project are finished when you crash or sell the car LOL
