Build Threads Details on Club Lexus 1IS owner vehicles
Project Boost
Old 05-30-11, 07:12 PM
  #46
baadhabit
baadhabit's Avatar
Originally Posted by edgy
congrats and well done ... loks real nice & great power also!
1 Q ...with that mani, couldnt you have possibly directed the output of the turbo down & forward Vs, up/forward/down behind the headlight to the foglight area & around to te IC..?
i was hoping to see the ouput set up to flow forward staying low, when using a manifold that hangs the turbo low like that (which i prefer...) with a small jog to the right into the headlight area and then around to the IC...you end up with a much shortened route/tubing to the IC inlet....
and a somewhat stealthier appearance
i do love NOT seeing a damn intake mani stetched across the top of the motor i do say!
i think you have your outputs and inputs mixed. i think youre talking about the charge pipe. sometimes people will run them this way is something else is blocking.
Old 05-31-11, 06:33 AM
  #47
dexlex2002
dexlex2002's Avatar
If you look closely the ran the hot side pipes that way to avoid hitting the ABS
Old 05-31-11, 06:33 PM
  #48
2jzsupra
2jzsupra's Avatar
for the tranny are you running a r154 or a w58? and nice swap i wanna do a 1.5 jz swap, in either my mk3 supra or my is300. 1jz head for the high revs and the 2jz block.
Old 06-01-11, 06:14 PM
  #49
Armyof1
Armyof1's Avatar
Its a built TCI tranny
Old 08-21-11, 06:51 PM
  #50
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Nice build overall. Who really cares about the cost, as long as it is done right, reliable, and you keep the AC.
Weapon F
IS F (2008-2014)
03-31-16 07:29 AM
huddleston
09-09-15 02:36 PM
tientony
SC- 1st Gen (1992-2000)
87
03-23-12 11:50 AM
Weapon F
01-23-11 12:15 AM
joeazy187
08-24-10 07:50 AM
Quick Reply: Project Boost
