ZachTriggs's SC300 from Texas
#124
[quote=1992Lexus;7453090
Did you you do any maintenance on it before the install or just dropped it in due, to time restraints?[/QUOTE]
Waterpump, belts, thermostat, nothing major.
Auto hopefully after tax returns or so next year I'll have enough cash to do an r154 swap.
See you there
See you there
#125
I got the kit off driftmotion. You have to cut the piping to your liking. If you plan to keep your A/C its a little tricky but if not its really easy. It was like $300 I believe.
#128
Good to see you got it on the road!!! wish i could of help out more on it, then the little to nothing i did. Get a set of ngk 4644's and hopefully thats it, if its still an issue you can try my coilpacks, common to go out esp for how old they are.
#135
Ngk 7092's work perfect for the swap. Check tps, ignitor coils, trans kick down cable position, vacuum lines, fuel pressure, and auch. The same old stuff on any swap. Also check timing on it too. My buddies broke up at like 2600-3000 rpm because of 1 tooth being off on timing. Make sure that it is set perfectly.
