My 2jzgte swap
#181
Well my suspension settled after putting it on the other night and the front sat about a 1/2 inch higher than the rear. I cut 1 dead coil off of the front and brought it down about a 1/2 inch. I have never been one to cut springs but I had to do it. Ill probably upgrade to coilovers when these shocks blow out.
#186
Not yet, I have decided I am going to go with the USDM turbos and will do the injectors at the same time and have it retuned. Hopefully making a little bit more power. Ill have to make another downpipe to work with the USDM turbos. I got some brand used brakes and installed an app radio.
#192
No, I think they are goodyear f1's up front. And she likes to move a little on roads with ruts.
#194
I found a set of old enkie wheels and slapped them on, And did the LS400 front brake upgrade instead of using my Brembo's. I used drilled stoptech rotors on the front and rear with Akebono pads. Goodrich braided lines. Cars stops ALOT better now. Here are some pictures...
