Build Threads Details on Club Lexus SC owner vehicles
so heres a few pictures of progress.
Old 02-14-12, 06:55 PM
  #241
WadeLovell
WadeLovell's Avatar
Originally Posted by MDSC
... finally got rear calipers to match the front now just gotta paint them same as front and order some sloted TT rotors F&R.
What prepr work did you do before painting them? I just got in a used set and want to do it once and do it right.
Old 02-14-12, 08:07 PM
  #242
MDSC
MDSC's Avatar
Originally Posted by WadeLovell
What is going on with those wheels? I see you are running huge PSI and I can't believe it doesn't scrape even with 75 in the back.
Read the thread, you got it all wrong psi is in airbags not tires, and if I have to dyi explain you how to prep something for.paint it.would probably be a good idea to have someone else do it
Old 02-14-12, 09:12 PM
  #243
//LRD
//LRD's Avatar
Amazing !!! nicely done MDSC
Old 02-14-12, 09:17 PM
  #244
Pnuge88
Pnuge88's Avatar
definitely one of the cleanest sc's i've ever seen! props to the work put into it!
Old 02-23-12, 08:25 AM
  #245
MDSC
MDSC's Avatar
thanks fellas heres little update, rest of interior SHOULD be done this week.
Old 02-23-12, 09:08 AM
  #246
Tabaka
Tabaka's Avatar
Looks great MDSC!
Old 02-23-12, 09:11 AM
  #247
94_soarer
94_soarer's Avatar
Hey can you access the expansion valve with the glove box and air bag removed like in this pic??
Old 02-23-12, 09:26 AM
  #248
718murdoc
718murdoc's Avatar
@ MDSC,, with the suede dash is there any glare while driving on sunny days as you would get with the vinyl dashboard?
Old 02-23-12, 09:59 AM
  #249
MDSC
MDSC's Avatar
no, that dosent even make sence honestly.
Old 02-23-12, 10:01 AM
  #250
MDSC
MDSC's Avatar
i dont know i didnt take anything apart just took the dash out, i doubt you can get the actual box out that contains the evaporator and heater core without taking the dash out.
Old 02-23-12, 10:11 AM
  #251
94_soarer
94_soarer's Avatar
Smh damn i need to replace my expansion valve, i heard u can do it without pulling the complete dash, jus removing the glove box & pass airbag if needed
Old 02-23-12, 10:53 AM
  #252
kez
kez's Avatar
The suede is really nice MDSC well done
Old 02-23-12, 11:25 AM
  #253
mk4r34
mk4r34's Avatar
Damn,your car is just looking So-So-FINE!!...everything is coming together nicely.How many coats of clear were laid on it?3-4?
Old 02-23-12, 11:42 AM
  #254
Luxor
Luxor's Avatar
That dash looks great! I've been wanting to do something like that. Is it a difficult task?
Old 02-23-12, 11:44 AM
  #255
MDSC
MDSC's Avatar
2 coats of epoxy primer, 2 coats of copper metallic base coat, 3 coats of black cherry kandy(which is clear based) and 2 coats of clear. thank you
Quick Reply: so heres a few pictures of progress.
