Build Threads Details on Club Lexus SC owner vehicles
1992Lexus.. Complete build thread with pictures and links!
Old 04-25-12, 05:25 AM
  #841
99SC42
99SC42's Avatar
Originally Posted by DoomLight
Dont forget to get that 3 bar map sensor. Hey folks not to thread jack... but i saw an Omni Map sensor for 1jz/2jz rated for 3 and 4 Bar for 99 bucks. Would that be a good choice? Or just get the AEM Version
I don't have any experience with them but i know exactly what you are talking about.
Ask LexusFTW IIRC he had one .
I am using a GM 3bar works great.
Or get the AEM3.5 those are not too exepnsive.
Old 04-25-12, 06:52 AM
  #842
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Originally Posted by PoGikoSc4
Hey Mark can u update us when u headin to TopSpeed if thats cool? I wana see this Beast in person during Dyno.
That is not any problem whatsoever. I will post up when i decide to head that way. I posted a different thread about Top Speed and other shops. I believe that this particular shop is out and Zen Motors is in. The customer experience was better over the phone than Top Speed. No offense to anyone affiliated with them.
About the map sensor, I was under the impression that the stock one will be just fine with my application. Why do I need a larger one??
I will be back tomorrow to fix oil leak, install exhaust, tidy up some wiring issues for the injectors, and start putting the bumper back on...
Old 04-25-12, 07:11 AM
  #843
94_soarer
94_soarer's Avatar
For like 6 seconds. I want to see this car make like 500hp.
If i made over 500whp on stock ecu & stock cams he will too, depending on the boost level this car should be making 600+
Old 04-25-12, 07:13 AM
  #844
cartmill
cartmill's Avatar
quick, what is the max psi you can run on the stock 1jz map sensor?
i was thinking it was 2.5 bar, so ~21psi...
someone correct me if i'm wrong.
Old 04-25-12, 07:37 AM
  #845
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Cartmill, I believe someone told me that 1 bar equalled around 17 psi. So if the stock map sensor that I am using is 2.3, then I could run around 35 psi of boost. is this correct? I may have forgotten the correct info. It may be in the 4200 page of this thread somewhere. lol
Old 04-25-12, 07:42 AM
  #846
99SC42
99SC42's Avatar
Cartmill you are correct .
Mark 1bar is 14.7 psi, not 17 psi
2.5bar is only for ~21/22 psi
Old 04-25-12, 07:56 AM
  #847
99SC42
99SC42's Avatar
MAP sensors measure absolute pressure. Boost sensors or gauges measure the amount of pressure above a set absolute pressure. That set absolute pressure is usually 1 atmosphere (1 atm) or 14.7 psi. This is commonly referred to as gauge pressure. Boost pressure is relative to absolute pressure - as one increases or decreases, so does the other. It is a one-to-one relationship with an offset of -14.7 psi for boost pressure. Thus a MAP sensor will always read 14.7 psi more than a boost sensor measuring the same conditions. A MAP sensor will never display a negative reading because it is measuring absolute pressure, where zero is the total absence of pressure (it is possible to have conditions where negative absolute pressure can be observed, but none of those conditions occur in the air intake of an internal combustion engine). Boost sensors can display negative readings, indicating vacuum or suction (a condition of lower pressure than the surrounding atmosphere). In forced induction engines (supercharged or turbocharged), a negative boost reading indicates that the engine is drawing air faster than it is being supplied, creating suction. This is often called vacuum pressure when referring to internal combustion engines.
In short: most boost sensors will read 14.7 psi less than a MAP sensor reads. One can convert boost to MAP by adding 14.7 psi. One can convert from MAP to boost by subtracting 14.7 psi.
Old 04-25-12, 08:11 AM
  #848
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Makes perfect sense. Thanks for the map sensor 101 college course...
Old 04-25-12, 10:25 AM
  #849
DoomLight
DoomLight's Avatar
I saw that omni map sensor on eBay. They were like 99 bucks.
Old 04-25-12, 11:48 AM
  #850
cartmill
cartmill's Avatar
quick, you mean 14.5psi.
14.7 is stoich for gasoline
Old 04-28-12, 01:39 PM
  #851
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Update..... Cartmill just left from street tuning. We have it pretty darn close... My thanks goes out to him for sticking with me.. Its almost a 2 hour drive one way from his house to mine... :-)
Drove around the city and highway for about 25 miles or so.. Everything went well. The metal o clip on the tranny is hitting the driveshaft. I remember it got bent somehow.. The oil leak is the driver side valve cover.. Its pouring oil.. I hope the 2JZ valve cover gasket are the same... Need to charge the AC.. Finish up some loose wiring under the passenger side floor board, and drive it to Atlanta.
As soon as we pulled up at Chevron, two guys in a old Honda Civic hatchback got out and went straight over to the car and said, "What kind of power are you putting down.... Oh nevermind, its a Borg Worner.. Alot " We just smiled...
Will be working on the car all day tomorrow and hopefully get alot done.. Will post more pictures up later...
Old 04-28-12, 08:28 PM
  #852
DoomLight
DoomLight's Avatar
Good news. Waiting on dyno results. Of course after you patch up the valve cover leak.
Old 04-29-12, 09:30 AM
  #853
spoolxexo
spoolxexo's Avatar
What kind of fuel and timing are you using?
Old 04-29-12, 01:42 PM
  #854
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
93 octane for now...
Old 04-29-12, 03:04 PM
  #855
spoolxexo
spoolxexo's Avatar
What about total timing at WOT?
Quick Reply: 1992Lexus.. Complete build thread with pictures and links!
