Build Threads Details on Club Lexus SC owner vehicles
1992Lexus.. Complete build thread with pictures and links!
Old 05-31-12, 05:20 AM
  #901
stockhatch
stockhatch's Avatar
I bet youre right that it is the angle of the extension causing your issues. I would try to source the Soarer extension parts man. They are factory parts that you KNOW will line up and work properly.
Old 05-31-12, 06:58 AM
  #902
99SC42
99SC42's Avatar
My shifter was extended , but i don't have any issues my trans right now " knock on wood' it's been great to me.
Like stockhatch said you need to redo the shifter extension part. That's your problem right there.
Old 05-31-12, 10:06 AM
  #903
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Thanks for the kind words. I will be sourcing the Soarer extension housing part in the classifieds now. The SC is going to the shop tomorrow for the A/C work and charge. I hope they will find no problems. I did replace the expansion valve, receiver/dryer, and all the lines from the firewall with new orings. Should be good to go. I did notice in other threads some are having to put in a relay for the compressor to turn off and on. I will know more tomorrow. I finally talk to the tuner an downer at Zen Motors yesterday. The tune is scheduled for 25th of June.
Old 05-31-12, 10:20 AM
  #904
cartmill
cartmill's Avatar
mark, you should be able to trigger the stock A/C relay with your AEM to kick the compressor on.
the shop won't be able to charge your AC unless the compressor is running
Old 05-31-12, 10:28 AM
  #905
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Cartmill, I beleive if my memory serves me right, the compressor kicks on and off when the button is pressed on the LCD. I will double check tomorrow and see if it does. If it does, is this ok or what????
Old 05-31-12, 10:34 AM
  #906
stockhatch
stockhatch's Avatar
Yes, that is fine. As long as the compressor clutch is engaging, you should be in good shape.
Old 05-31-12, 01:21 PM
  #907
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I will double check when i get home in the morning. My new turbo blanket arrived today. Still no stinking valve covers.
Old 06-01-12, 09:09 PM
  #908
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Went to the ac shop this morning and waited about three hours for them to charge and pull a vacuum ... Went into the AEM and turned the switch to find out the patch harness didnt have any wires for the ac trigger or the clutch. we trouble shooted the wiring and figured i need to run the wires myself and assure it works by the button on the LCD. He did jump the relay and tested the AC and it blew ice cold, which is good. I will try to tackle this when my new HKS turbo timer comes in. I also notice the driveshaft is getting louder and louder, imo. I really dont think the tranny is doing this but the noise from whining is getting worse. I wonder if the driveshaft bearing is bad. Or something else, its getting old very quickly. Any ideas?
My buddy and I went and looked at a Toyota Supra with a 2jzge single turbo tonight. It was black on black with the W58 and a piggyback setup. I was very impressed.with the power and the instant torque. He ended buying for 15,500. Its a 1995 with factory TT wheels... It makes me wonder to sell this thing and buy a Supra.
Old 06-01-12, 09:14 PM
  #909
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Here is one shot i took from cell.
Old 06-07-12, 05:18 PM
  #910
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Update on the AC. I found out you need pin labeled A17 and A27 for this to work correctly through the AEM. The white wire on the 1JZ harness goes to pin A17 on AEM, and the blue/white wire goes to the A27 on the AEM. You can also adjust the settings in the AEM for when to turn on and off. Go under the tab labeled TOOLS, the Configure Settings. Go from there. My idles pretty smooth, but will mo better once tuned at the end of this month.
Old 06-08-12, 08:17 AM
  #911
cartmill
cartmill's Avatar
so does the AC kick on with the a/c button now?
it only passes through the ECU so it can raise the idle to make up for the extra load and turn off the compressor when you're in high RPMs.
mark, trenton just bought a 97 silver supra (NA) for 12000...
no thanks... i think i'd rather have a rowdy single turbo 6spd SC300 for the same price, and way smoother.
Old 06-08-12, 08:22 AM
  #912
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Everything is as normal as it should be. I cant even keep on cold for very long. It gets that cold.
Old 06-13-12, 08:26 PM
  #913
skirts
skirts's Avatar
Cartmill, isn't that what Trenton has always wanted besides like 17 different SC's? Havent talked to him in a couple months I had no idea he got one.
Old 06-14-12, 07:20 PM
  #914
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Only over a week away for the big moment. Man this thread is insanely long, but overall great info. I am still waiting on the valve cover to be redone with a new fitting. Hopefully it will be by this weekend. I have an appointment with the dent people to remove all the small dents and dings on Tuesday.
About the tune, I will post the video on here at the end, but with it being so long, I will create a new thread on the dyno pull.
Old 06-18-12, 05:59 PM
  #915
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Just a follow up!
Tuning will be done on Monday June 25th, 2012 at Zen Motors...
Scheduled time is 10 AM
I will be posting the dyno graph and the dyno pulls in thelinks at the end of the thread.
The car will also be at the Atlanta, Georgia meet this weekend, if all goes well.
Quick Reply: 1992Lexus.. Complete build thread with pictures and links!
