My sound system Build.
subscribed, interested to see how your setup will turn out. Although your choice in head unit does seem sleek, consider a real double din, It's even more sleek
It's just so convenient in so many ways like updating your interior, upgrades your sound system, navi, movies, it's worth the extra $
Lol. I did just the opposite of your set up. Didn't want my rears so powerful, so I ran 3 way 6x9's in the door, and the high mounted tweeter. Rear deck was used dkr rear fill only.
Your set up looks REALLY NICE. good luck w/ your project. Anxious to see the end results.
Thanks for the input guys! advice is greatly appreciated here!
soo are u considering a 5 channel? 2 for the fronts and 2 for the rears? the last 5th channel aka a mono channel to run the sub? or using whatever the **** the stock system used? i havent torn into mine yet, but am curious to see, i seen that the stock sub is 1ohm, if so id reconsider the D4 model of the Boston and go with a D2 so u can keep that 1ohm load. get the most power out of the amp as you can
u will be able to get the same quality out of a D2 as your gettn from the D4, no problems there...ha i had 4 8's in my old spl car, i could play any song from as low as 22hz to a peak of 63...thats a HUGE variety and not only did it do it at a 146 it did it with sound quality, its just about how u tune it man! and hte box, but considering the rear deck and it being free air, i see the dynamat u ordered helping ALOT with the rear deck rattle/flex that i ahve noticed in mine
so far i carved out the mounts so they sit as flush as possible and cut them to allow even shrinkage of the material as it dries.
![](http://i1087.photobucket.com/albums/j462/Rey_Orta/2011-09-12140252.jpg)
![](http://i1087.photobucket.com/albums/j462/Rey_Orta/2011-09-12145138.jpg)
once the material is stable enough, they will be ready for the install.
Alright guys. The rear mounts are curing at the moment so i cant install them yet. but i managed to installthe right front speaker.
what i did was take out the housing and dremel out a hole big enough for the new larger speaker to sit flush. and filled up the housing with a generous amount of fiber fill. to better the sound.![](http://i1087.photobucket.com/albums/j462/Rey_Orta/2011-09-14145049.jpg)
this is how the speaker sits now. im waiting for the sealant to set before i put this guy back in.
![](http://i1087.photobucket.com/albums/j462/Rey_Orta/2011-09-14141528.jpg)
yeah i want to make sure i do it the right way once. i'm pursuing perfection. since some of the stuff was a "hookup" by a friend, theni can give you an estimate of how much it would be in retail once im done. how does that sound?
Ali12978
01-18-19 02:53 PM
jpvarghese
12-04-07 07:15 AM
slo86
19
10-05-05 07:06 PM
