Nice pickup! I was looking into buying these as well,since brakes have always been something I can't get myself to drop a ton on. Looking forward to hear how you like them!
Very nice! Will the added thickness of the powder on the spacers affect the fit of the hub hole (don't know if that's what it's called)?
I believe yes. And if so I am prepared to sand it down. I will find out tomorrow when I pick up my CV3's. I'll let you know
Ugh, agreed. Ceika is the only one that I feel isn't an arm and a leg compared to all these others in the same dimensions. An 8 pot 16" (ish) kit from Ksport would have been around 3800 alone just for two discs and calipers... No thanks.
Originally Posted by carlos
Also, is the rear rotor hat made of steel or aluminum?
No clue, but judging by the weight I'd say steel. Then again I'm weak and in need of working out.
If I may, I'll point you to www.ceika.com for that info.
Hopefully it is, otherwise I hope you never intend to use the e-brake!
Very nice build! It's going to look amazing with those massive brakes on.
Carlos> The rear hat is made of alloy too but there is a steel ring inside for the parking brake shoes of course. Also website is ceikaperformance.com not ceika.com ;-)
Damn, those things are HUGE... You keep doing big things man, keep it up!!!
Thank you sir for the kind words.
Originally Posted by CEIKA
Hey guys,
