"Biturbo 2JZ swapped' Soarer Build Thread"
#79
I'm going to mount it in this weekend starting right now! I picture you guys soon on this, THIS CAR going to roll on this weekend for suuuure!! I can't wait anymore!
p.s. just got myself an instinctor, just in case, I better have it thank loosing my car!
#81
Update May 3th part!!
I said it have to get out, so THIS IS IT!
So on Wednesday, my friend came in and said "let's finish the harness, tape, cover and everything and we go for a ride!!!" I love his optimistic opinion but I was a little bit less enthousiat than him.. like it was impossible to finish everything we need at least to have a little ride....!![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
Well, be begin by the harness, just to clean everything up inside the car because it was very messy!!
by https://www.flickr.com/photos/153934546@N06/, sur Flickr
Now that's clean!!!! By the way, the AEM FIC is not yet connected.
For the engine bay side of the harness we've had to make everything work, rather then putting everything inside the existing 2JZ harness (pain in the *** job), we've made a second harness.
We finally didn't make it to get the car out as I espected.
Now on friday, on my way home, get here on CL to get my message and realized that I forgot to write "Tow Hook" on my to do list!!! Was like.. ******, it's 2H PM and everything close at 5!!
Give a rush on that, went inside the garage, make a 5min plan in my head, and went to buy the stuff I need. As I have already the Benen Tow Hook, it "only" take a solid braket to mount it! So here the stuff needed (by the way, the 1/2 size 5 inches long bolts were finally too long and went for 1/2 size 3 1/2 inches long ones that fits perfect!)![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Braket finish before paint.
Everything mount and installed (Trush me, the tow hook will brake before my braket!!)
Finish setup for the harness and installed the Canister, and loll, need a longer vaccuum hose for it!!
2 friends of mine where there on that day, so will I show them how to installed the front bumper I've gave a rush to reassemble my interior (don't want my foot jam intook the falling wires from the underdash! And also you can see the final look of the tow hook! Also finished the left side inner fender.
YEAAH! Out finally!!! Running great, always for now the low idle and running rich, I'll see later after rolling it a little.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
the "running rich" problem as been solved by rolling with the car for a good 30min arround, thanks to ALI SC3 for the hint! At cold, it stay a low rpm (600), and when hot, it stay a 800-900 like the 1JZ used to be.. so don't know yet how to make it higher when cold!
Also have a turbo oil leak for the return line, I'll order a new gasket and have to damn change it.. It would be fun!!![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Also, the second turbo don't seem to boost at all.. my boost peak at 9psi, then drop to 7 until 5000rpm and then drop till I shift gear. I'll check this with my friend this week. Maybe an actuator blocked or an VSV valve that don't work fine.
So for now that's where I am on this project!!! At least it run, and run great thanks to my buddy Maxime and all my friend that help me!!
And thanks a lot for your comments, questions and appreciations!! I like to share and help other if I can!![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Last edited by biturbo632; 02-10-22 at 07:14 PM. Reason: picture aren't uploading anymore
#83
i love the stance on this car. amazing.
how many ponies does it produce?
#88
Updates!
Me car was running great! But the timing belt went closer to the block (wtf?) and push and destroy herself on the crank sensor plate that is mount on the sproket of the crank...
Result: this "gear" or washer on what the crank sensor make his reading, went of the sproket and spin free. My motor is no longer starting!![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
By chance I was at 400ft from my friend house (that's were I was going so...) Now my car is in his garage already on jack stand
the fun thing about this is when I call him to say I'm stock near him, he said me his tractor mower broke.. at the same time. Epic.
Well we've try the tow hook and it work fine! But I'll have to reinforce it a little bit because it have bent a little to the left as we entered his parking (he towed me with a chain) So it have to be reinforce for lateral towing strengh if you understand what I mean!
Let you know soon what's next as we order a few thing to get it move again:
-New timing belt already loll
-New sproket/crank gear for timing belt
-New tensionner pulley as we thing it's the fault for the timing belt that have come closer to the block.
-New Oil return gasket for front turbo as, I have a leak!
-New solenoid for the IACV as mine is broken and it's the reason why my sequential turbo aren't working ( but still work in TTC mode,.. awesome!)
After what, I will run an 500km arround and if everything goes right, I'll go on tuning it with the AEM FIC and see if I need injectors!
see ya soon!!
see ya soon!!
#89
Thanks!!
I dunno yet as my car cannot move at the moment! I would like to pulse an 375whp at 16psi.. that's my goal. Power in safety mode for the turbos! ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Yes man! As I follow the thread you've made, and you seem to really make your self one, see my next post, I'll show you how I do mine!
twin? Man you mean your car is like mine! I gotta see this!![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Hahahaha! I'd love too, a lot of people want one, but as I'm RHD and 90% of the one who as me one are LHD, I need an LHD car to make them. But still no problem for doing one for an RHD as I will use my car for testing. (true.. this is a PAIN in the *** to make that hidden gauge pod!!)
Blue carbon![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Thanks man! Love to see canadian guys here!![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Blue carbon
#90
For Menty, and those who want to know how to mount a tow hook like I've done. Here is the "how to":
1. Things you need for making this
-drill
-grinder mount with a cutting wheel.
-a solid vice mount on your workbench.
-permanent pen/chalk
-rule or measuring tape
Things you need to buy:
-Tow hooks! (doh!) here it's an Benen Industries screw type tow hook for an S2000
-1/2 size, 3 and a half inches long bolts with lock nuts (here in the first pic was 5inches long one, my error!)
- a 6x10 inches, 1/4 inch tick plate (or more, but you will have to bent it so....) It could be 5x10 but It doesn't seem to exist.
-2 extra strengh nuts that fits the tow hook for mounting aplication
- and finally a 3/8 size, 3inches long minimum bolt with nuts, you'll see below why.
Here is the tamplates with all the measure. the little peace were I wrote "ply" would be bent at approx 80 degrees
With the cutting done
On the measure plate picture you'll see two dotted line, sorry the one a the right as to go on all the width of the plate. you have to bent the plate in a shape like this
So it would follow the frame rail. You can see here the "ply" bent at 80 degrees that suit the aluminum beam for extra strengh for towing. ( I do not have bent all the plate because I would have broke my already ruin vice.
For the "where to mount this braket" remember we are on the right side of the car. Between the beam and the frame rail I have a braket. juste remove it for now, and drill a 1/2 size hole through the insert and through the frame rail.
After what you've got drill through the braket where you hole in the frame are. I suggest you do those hose after you've made your hole into the frame as doing them really perfect at 90 angle is pretty hard! So just use the drill or you pen to mark the braket through the hole in the frame for perfect (or almost) fitment! It have to be tight!! Use the 1/2 size 3and a half inches long bolt here!
Here's the how it have to hang after. See it clean the Greddy intercooler pretty good
Now test fit the bumper, and be carefull, the braket fit tight into the grill!!! Watch for you paint!
At this moment, put the 2 nuts on the Tow hook and find where you want it, inside, near, outside, easy to remove or not etc... you have 3inch to adjust like you want.
As I want mine as close to the bumper possible, and that I don't want to remove it everytime, here where I mark my braket
Now weld it to the braket... I remove only the tow hook when I weld it but left the polish metal part that screw in in place.. I was nervous about the nuts to twist. MAKE SURE TO HAVE IT WELD ENOUGH!!
And also VERY IMPORTANT make sur you've tighten your tow hook properly with the bolt, if not, I may occur that when you will screw your two hook, it can be at an angle and not perfectly horizontal.
After what, cut the extra metal that is after you weld nuts, trim around a little with the grinder to be sure it fit inside the grill without problems, round the edge, etc. I, also, finally use the 80 degree bent end on the plate to screw it through the beam with the 3/8 size 3inches long bolt. Just mount the plate with your two 1/2 size bolt that goes through the frame rail and drill through the beam and through your plate, that's the easiest way. That will had strengh for lateral towing habilities.
So you're plate should now look like this.
Here a picture that showed the 3/8 size 3inches long bolt through the beam and the braket for extra strengh
Prep it, Paint it, mount it finally, and then screw in you're tow hook
If you welded your nuts to have the tow hook that clear the bumper for easy removal, you can do this after installing you bumper.
Finally mount!!
So the thing is, it as enough strengh to be tow, I tested it. But it's not enough strengh if you have to make a tight 90 degree turn into a parking spot or something when towed. So I'll had a 1/2 tick steel bar (longest possible) on the braket on the other side of the bolts where the tow hook mount, and solder it for it to be impossible to ben again (it move half a inch to the left but I don't want this to happened again!)
I'll update a picture of it when done!!
Enjoy!
For a great price for you tow hook, refer to ebay.
-drill
Finally mount!!
Enjoy!
Last edited by biturbo632; 02-10-22 at 07:36 PM. Reason: picture aren't uploading anymore
