"Biturbo 2JZ swapped' Soarer Build Thread"
#121
Hi guys! I'm up for a lil update!
I'm going for some little thing for this summer... as the time goes by I haven't got much time to work on my car and still, I'm working a lot at my day job!
Here's a list of what I would do:
- Go bigger inner fender for the front because of tire rubbing.... lolll
- remove and install my rack and pignon because of a leak of oil. Would be refurbish as... finding a new one for an RHD car.. well.... no.
- Fuel upgrade for now and for the futur of some turbos somewhere in the next years
- 800cc SARD injector
- Aeromotive 340lph Fuel Pump
- Tomei Fuel Regulator
- no bigger line needed for stock turbos for now.. it's just that I'm hitting the fuel cut and I don't want to loose another motor!
- Gonna install my 10inch subwoofer the "ok" way in the stock area where it's suppose to be!
- little trick and repair here and there on the interior
- and for the final when I'll get it out for the summer time, I'll get a tune for the car to be perfect and I'll repair and paint both side as my fender are rolled pushed and cracked... so gotta fix that, plus.. having some goodies to install!!
Stay tuned!
And.. for the wait, here's a lil photoshooot just before I stored it for the winter! Enjoy!
by https://www.flickr.com/photos/153934546@N06/, sur Flickr
Stay tuned!
Last edited by biturbo632; 02-10-22 at 07:55 PM. Reason: picture aren't uploading anymore
#128
Thanks!!
Wellllllll! I purshased oem 97+ side skirts and door moldings, I recently add the rear Fujin lip to my parts so more updates soooooon!
#131
Update 2013-03
So now I've been able to work on my car and take the time to take some pictures!
Here's some things I've ordered!
- SARD 800cc side feed high impedence injector direct bolt-on
- Some OEM supra oil filter at good price(that's the reason for 5 of thems)
- Finally recieved my Mishimoto alluminum top radiator hose
- Black duralock nuts with lock nuts because I used to have the blue one but it ain't look good on blue vs-xx!
- Fujin rear polyurethane lip from RideSkinz!
- OEM 97-00 side skirt with door molding (I use to have them since the end of summer 2011 but since I broke my engine... I never got time and money to work on them!
And now some little work I'm doing. Since I have a double din radio with 6.5in screen, I wanna be able to plug some things like camera, cellphone (for music because I already have the module for the bluetooth via the radio!)
So.... there's a smoke cup behind the center arm rest that I use for.. nothing other the blocking the hole it would make if I remove it sooo, I take it appart.
Make groceries at the electronic store and come back on some ideas
And here's the final result:
Now I have a access to plug in whatever camera or in this case, my Gopro to be able to see live feed from it onto my radio (and waaaaaay easy menu reading!)
Also able via an white/red (left/right) RCA to Stereo cable, I can listen to my cellphone music, exactly like an auxiliary input!
The other thing is an USB. No I don't have a PC in my car but since the Gopro can only be charged via usb, I've dissamble the smallest 12v usb connector I've find on the market and installed it there!
So live feed, plug in 12v.. my camera will stop filming only when my 32go card will be full!!!
Last edited by biturbo632; 02-10-22 at 08:10 PM. Reason: picture aren't uploading anymore
